11-30-2009, 04:23 PM
Member #2120
1995 400 Floods Out
I have a 1995 Polaris 400 4x4 that floods out when starting or running. I rebuilt the top end and went through the carb for my Dad so it would be ready for ice fishing. The atv ran great. I used it around the house for about a month with zero problems. Sent it off with him to bring to the lake and he used it for half a day and called to tell me it wouldn't stay running and ran poor when it was running. Got it back to my house and went through it and found the plug gets soaked when trying to start it. If I dry the plug it will start and sputter then die. I pulled the carb apart again and check the float level, needle, and seat. No problems. Check compression. I have about 110 psi. Probably a little low from fuel soaking the rings. Check for spark. Spark looks ok. Pulled the flywheel to check the flywheel key. Flywheel looks to be in good shape and the key was intact. I am so lost. Anyone have any direction to go? Don't know what to test next. Thanks
12-01-2009, 12:07 PM
Member #2120
I think I am going to try a used cdi box.
12-19-2009, 07:09 AM
Member #2120
Well I have not gotten a cdi box yet. But I replace the crank seal that looked to be leaking no difference.
12-19-2009, 01:17 PM
Member #2326
2 stroke right? Check the choke cable to make sure it isn't pulling open, sometimes they hang up, replace spark plug.
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
1995 polaris 400 cdi box, 1995 polaris atv run without half choke., 2007 polaris hawkeye flooding out, atv floods out, atv floods when trying to start, float 1995 polaris 400t, floods 1995 in minnesota, how to start flooded atv, my atv floods when i try to start it, polaris 300 flooding, polaris 400t atv, polaris hawkeye float level, polaris hawkeye flooding, what make a polaris flood out
