Old 12-09-2009, 07:41 AM
Ben2009's Avatar
Member #2237
2004 Sportsman 700 EFI Clutch Problem
I have a 04 700 sportsman efi. It is very hard to shift I usually have to shut the machine off to shift but at times it seems perfectly normal. It has a new polaris belt and I am curious if anyone knows what could be causing this or what it takes/costs to get it fixed?
Old 12-09-2009, 07:45 AM
two things pop to mind.
check shift linkage
check belt tension
does the machine want to move on its own if it is in gear with no throttle or brake?
Old 12-09-2009, 07:47 AM
Ben2009's Avatar
Member #2237
It does want to move when its in gear most of the time but sometimes it dont!
Old 12-09-2009, 07:59 AM
then that really leads me to believe belt tension. you might be just on the edge of it being too tight were sometimes the primary is able to catch the belt enough at idle to grab it and make it spin, and sometimes it doesnt. im not saying belt tension is the answer but its something i would really look at given your problems. sadly, im a parts guy, so i have no knowledge how to do it. at this point i would have you talk with our service manager. get yourself a good service manual. you can get a clymers or a haynes for like $33 or even the OEM one but those are usually $50-$70. any of them should have pictures and detailes on how to do belt tension adjustment and other troubleshooting. if anything else comes to mind i will let you know
Old 12-09-2009, 10:57 AM
Ben2009's Avatar
Member #2237
Thanks!
2004 700 polaris sportsman 700 efi not shifting well
2004 700 sportsman polaris clutch adjustment
2004 polaris 700 clutch adjustment
2004 polaris sportsman 700 drive belt problems
2004 polaris sportsman 700 manual
2004 polaris sportsman 700 service manual
2004 polaris sportsman 700 shifter
2004 polaris sportsman 700 troubleshooting
2004 sportsman 700 belt change
2004 sportsman 700 belt location
2004 sportsman 700 clutch adjustment
700 sportsman clutch adjustment
polaris clutch adjustment sportsman hard to shift
polaris sportsman 700 clutch issues
polaris sportsman 700 efi hard shifting
polaris sportsman 700 shift linkage
polaris sportsman 700 shifting is very tight
problems with polaris sportsman 700 belts
sportsman 700 bre pedal loose
troubleshooting 2004 polaris sportsman 700 twin
