Using Seafoam - Polaris ATV Forum
post #1 of 12 (permalink) Old 10-12-2011, 06:40 AM Thread Starter
pepper1126's Avatar
Using Seafoam
You all gave me the advice to use Seafoam in all my ATV's. I just purchased some from WM yesterday, can you all give me some advice on how to use it? Is it one can to one tank of gas?
pepper1126 is offline
post #2 of 12 (permalink) Old 10-12-2011, 07:19 AM
AKStew's Avatar
One can to one tank of gas would be WAY too much! It should say on the side of the can and I believe the dosage depends on whether you are trying to clean/restore or just using it as a preventative measure.
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
AKStew is offline
post #3 of 12 (permalink) Old 10-12-2011, 08:34 AM
tt425's Avatar
Only use 1oz per gallon of gas. Too much may cause problems.
tt425 is offline
post #4 of 12 (permalink) Old 10-12-2011, 08:39 AM Thread Starter
pepper1126's Avatar
Well on my arctic cat, I am trying to clean and prevent. On my polaris, I am trying to prevent. so how much should I put and should I wait till I fill up the tank again?
post #5 of 12 (permalink) Old 10-12-2011, 08:52 AM
antoniodef's Avatar
Personally, I run 2oz to 1 gallon to clean, 1oz to 1 gallon to maintain.
2015 Sportsman 570 Touring EPS - 26" Big Horn 2s, ITP Delta rims, Polaris 3500lb winch.
Sold - 11 TB 330, 11 SP 500, 13 SP 500
antoniodef is offline
post #6 of 12 (permalink) Old 10-12-2011, 08:59 AM
SMP63's Avatar
To clean/prevent i used 3 oz. per gallon for a couple of tanks then dropped back to 1 oz. per gallon. To prevent, 1 oz. per gallon. I started this when the tanks were 1/2 to 3/4 empty. To make it simple would treat both bikes the same. Its not gonna hurt the Polaris. I use Sea Foam in everything!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
SMP63 is offline
post #7 of 12 (permalink) Old 10-12-2011, 01:18 PM
bgirard420's Avatar
Indeed, 1 oz per gallon is the manufacturer's recommended amount for prophylactic fuel treatment. Agree that up to 3 oz per gallon would be ok for a deep cleaning but unnecessary for continued use. A 16 oz can in a 4.5 gallon tank would be a lot, but in your auto a whole can would do just fine.
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
post #8 of 12 (permalink) Old 10-12-2011, 03:22 PM
cwlongshot's Avatar
Sea Foam | How to Use Sea Foam Motor Treatment
Read up and be enlightened!
Using too much will not hurt anything, IIRC its a 100% petroleum product. BUT is a waste of $$... I personally use 1oz per gallon as a preventative and 2-3 oz per gallon in a problem engine.
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
post #9 of 12 (permalink) Old 10-12-2011, 04:24 PM
antoniodef's Avatar
On a side note...I have a 99 Suburban with 200k miles. It's so clean, I will keep this sucker forever. It was starting to get a little rough idle. Threw in two bottles of Seafoam with 15 gallons of gas to see if I could clear it up. Burned about 7 gallons so far, and I can already tell the idle is improving. Great stuff.
post #10 of 12 (permalink) Old 03-07-2012, 06:47 PM
Kong's Avatar
If you use a too much Seafoam, if there is water in the gas, will it burn out as white exhaust, with a bad smell? I probably used too much. I notice it more when I use gas from one particular station. I'm not loosing any coolant, so that's the only thing I can think it is. Any ideas about have too much in your tank, or it just does not like Go Mart gas. The bike runs great otherwise.
<a href=http://i283.photobucket.com/albums/kk293/luv2eather/Sigs/Kongsig3.png target=_blank>http://i283.photobucket.com/albums/k...s/Kongsig3.png</a>
Kong is offline
"Seafoam" wyoflyfishing ATV Repair and Maintenance 18 01-10-2010 01:57 PM
