Transmission grinding 2003 Magnum 330 - Polaris ATV Forum
post #1 of 6 (permalink) Old 10-27-2011, 03:40 PM Thread Starter
MagnumRider's Avatar
Unhappy Transmission grinding 2003 Magnum 330
Hi All,
Recently, my 2003 Magnum 330 4x4 starting grinding when I try to put it into high gear. Low gear is fine, as are reverse and park. Sometimes it goes right in but usually there is at least some grinding before you hear it pop into place. I've never seen anything about transmission fluid, but it would seem likely with an auto tranny. Any suggestions besides take it to the shop?
MagnumRider is offline
post #2 of 6 (permalink) Old 10-27-2011, 06:49 PM
Bruce! is offline
post #3 of 6 (permalink) Old 11-25-2011, 12:09 PM
swampdog69's Avatar
did you get a answer on your trans i have a 330 magnuw with the same thing thanks
swampdog69 is offline
post #4 of 6 (permalink) Old 10-24-2012, 08:27 AM
callsan's Avatar
I seem to be having the same issue...Anyone have a solution to this crazy probem? I haven't torn it apart yet....I want to try and find a fix before I tear it apart.
callsan is offline
post #5 of 6 (permalink) Old 10-24-2012, 10:22 AM
InRBigness's Avatar
Check the adjustment rods as well as the bell crank on the top of the tranny. They sometimes get a crack in them that allows them to flex but keeps the rod from fully shifting into gear
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #6 of 6 (permalink) Old 12-09-2012, 03:57 PM
nd48463's Avatar
I am having the same problem and am wondering if maybe it is related to the rear brakes?? I just bought my 2003 Magnum 4x4 and it sometimes grinds when putting it into high gear. It also needs rear brakes, so I was thinking that maybe they are related since you have to have the rear brakes on to engage high gear.
nd48463 is offline
I need a transmission for a 97 polaris magnum 425 4x4 barber878 ATV Parts for Sale 0 03-23-2011 07:11 AM
00 magnum 2X4 transmission clicking in neutral sassah ATV Repair and Maintenance 0 01-31-2011 04:33 PM
2002 magnum rmk transmission problems mech63s ATV Repair and Maintenance 3 01-01-2011 02:13 PM
2002 magnum 325 4x4 Transmission leak dude ATV New Members 1 12-16-2009 05:36 PM
WTB 325 Magnum transmission andrewspivey ATV Parts for Sale 2 10-30-2009 09:59 PM
