Old 12-20-2009, 11:46 AM
palumbogio's Avatar
Member #2361
ecm electrical problem
Hello to everyone
I'm new to the forum.
Last week my brother install a new gel mat battery on my wife 2003 Polaris trail boss 330 unfortunately he installed the wire backwards and try to crank the atv than he realized his mistake and inverted the wire the atv started and run for few minute when he realized that a smoke came from the front of the atv the way he describe to me is the electronic control module box before I replace the ecm I would like to know if maybe something also be wrong like fusible link or fuse I'm trying to save 200 + dollars if I can at this time I don't try to start the atv yet to avoid future damage and if anybody as a copy of the wiring diagram of this atv I will be really appreciated so I can check all the wiring.
Thanks in advance for all your help Giovanni
Old 12-20-2009, 12:08 PM
First off, welcome to the board! And second OUCH!
2000 polaris trail boss where is fuse box
2003 330 polaris trail boss wiring diagram for battery
2003 polaris 330 trail boss wiring diagram
2003 polaris trail boss main fuse
atv ecm repair
controller module polaris 330
ecm for atv
polaris 330 ecm module
polaris atv 330 wiring schematics
polaris atv ecm
polaris atv ecm problems
polaris ecm
polaris ecm module
polaris ecm problems
polaris electronic control module
polaris trail boss 330 wiring diagram
polaris trail boss ecm
polaris trail boss module controller
polaris trailboss ecm plug diagram
where is the fusible link located 0n a 2003 polaris atv 330
