Old 12-23-2009, 11:08 AM
crackenzag's Avatar
Member #2392
06 hawkeye information
Hello all. I am an ASE certified automative repair shop owner ("oh great... here we go" says everyone... lol) The only reason I say that is to let anyone know who may think that they have info over my head to let me have it anyway.
I am having an issue with my 06 hawkeye. It's having a horrible time idling.
I read that these quads have a TPS (throttle position sensor). I found it. I also found that if the contacts are closed, the quad will not run. Like the ignition is cut off as soon as the contacts are closed. Is it supposed to do that? I have removed the carb and cleaned it well, removed all the jets and blew all the passages out with compressed air. As long as I hold some pressure on the throttle to open the TPS contacts, it will idle, barely. But as soon as I let completely off the throttle, not even enough to actually move the throttle plate in the carb, the engine just shuts off.
I have adjusted the throttle cable so that the contacts stay open and the quad does idle but not very well. It actually seems a tad worse than before I went through the carb. If i pull on the choke, it idles much better. If I spray a bit of carb cleaner through the bowl vent openings in the carb, runs much better. Also backfires at times. Seems to me like I'm dealing with lack of fuel. but why? and why at idle? I'm more of a fuel injection man than a carb man (I'm ony 29, carbs on cars are before my day) but I have a grasp on what they are all about.
anyhow, I was hoping someone out there can say "oh yea! I know what causes that!" and can shoot me the answer... as if it is going to be that easy.. thanks alot guys and gals! and I hope someone can help!
Old 12-24-2009, 11:36 AM
Moose heated grips and thumb
Old 12-26-2009, 08:19 PM
eddiesbenz's Avatar
Member #2200
Sounds like lean fuel screw setting. I re-jeted mine with dynojet kit. In doing so, I discovered mine was set only 1 turn out. To lean.
According to service manual it should be 2.5 turns out. It is consealed by a metal plug that must be remove to gain access to adjust screw.Purhaps you did not see it.The plug is on the underside of carb by float bowl. The carb has to be removed gain the access needed to pull plug.
Old 12-28-2009, 09:41 AM
atvjunkie821's Avatar
Member #2326
Do you know about the recall?
http://www.pritzkerlaw.com/polaris-hawkeye-recall/
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel:www.youtube.com/user/tinkerman01
Tags
carb, fuel, plug, stalls, tps
06 hawkeye 300 idles but shuts off when given throttle
06 polaris hawkeye
06 polaris hawkeye recall
2006 hawkeye polaris carburetor needle
2006 polaris hawkeye carburetor
2006 polaris hawkeye idle
2006 polaris hawkeye idle issues
2006 polaris hawkeye recall
2007 polaris hawkeye tebuild carb kit
carburetor adjustments polaris hawkeye 300
how does the timing set on a polaris hawkeye
polaris hawkeye 300 4x4 carburetor adjustment
polaris hawkeye carburetor problems
polaris hawkeye cold idle
polaris hawkeye idle problems
polaris hawkeye recalls
polaris hawkeye wont idle
where is the idle on a polaris 300 hawkeye
