1988 trailboss 250 4x4 gear pattern - Polaris ATV Forum
Old 11-14-2011, 11:37 AM
bowdog's Avatar
Member #9999
hello i just purchased a 88 250 trailboss 4x4, never had one it needs a little work and ill be fixing it up. can anyone tell me what position the shifter should be in for 2 wheel and for 4 wheel drive, it says on the side on demand but i dont see a button to engage 4 wheel, i know there are 4 slots for the shifter starting from the top. obviously i know when its in neutral and reverse but not 2 and 4 wheel drive. also where is the filler hole to put oil in the bottom engine, i see the hole for trans but not engine.im not an idiot just never owned one of these. thanx
Old 11-15-2011, 07:24 PM
pmtrautman's Avatar
Member #14375
OK the gear selector is all the way forward is high range and all the way back is low range. There is no 4x4 selector because it senses slippage in the rear wheels which automatically engages the 4 wheel drive. it is 100 % mechanical unlike the newer one which r controlled by a magnetic coil. There is no oil the the crank case of this engine because it is a 2 cycle and the lubrication comes from the oil mixed with t he gas. I hope I have answered your questions.
/transmission fluid fir a 1988 polaris trail blazer4x4
1988 polaris trail boss 250 4x4
1988 polaris trail boss 4x4
1988 polaris trail boss 4x4 review
1988 polaris trail boss wher to put oil
1988 suzuki 4 wheel dr. shifting pattern
1988 trailboss 4 wheel not engaging
250 polaris 1988 gear padrin
88 polaris 250 trail boss gear lever
88 trail boss 4x4 starting issues
how does 1988 polaris trail boss fourwheel drive work
how to rebuild a tranny for a 1988 polaris atv
1988 Polaris no spark??? trailboss2x4 ATV Repair and Maintenance 6 10-03-2015 01:36 PM
1988 Trailboss 250 -- brakes same on other models??? cscmc1 ATV Brakes & Suspension 2 10-20-2011 10:48 AM
1988 Yugo offroadohio Everything Else 1 09-25-2011 06:24 AM
1988 trail boss 250 2wd 21yearoldWhoLoveHisGarage Polaris Trail Blazer 4 03-27-2011 08:33 AM
1988 bronco II trail rig offroadohio Everything Else 0 09-01-2010 06:12 AM
