12-24-2009, 11:00 AM
Member #2398
battery not charging
hi,
i have recently bought a polaris magnum 425 and i am having problems with the electrics. everything works fine apart from the battery is not charging. i have checked every single wire and nothing is shorting out no fuses or regulators have gone. i have 55volts coming from the stator and 16volts from the regulator but when the regulator is connected to the battery it doesnt show any voltage going into the battery. also when the lights are turned on the voltage on the battery drops to 9volts this is with a brand new battery.
any ideas?
cheers
dale
12-24-2009, 04:02 PM
Member #2326
Look at the Voltage Regulator on the left side behind the front bumper, it's probably bad, might check it's grounding though
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
01-16-2011, 02:00 PM
Member #11127
Originally Posted by dale
hi,
any ideas?
cheers
dale
How did you check the volts from the stator?
95 polaris magnum runs but battery wont charge, atv battery not charging, battery not charging on polaris atv, how to check if polaris ranger is charging battery, polaris 330 magnum battery, polaris 330 magnum not charging the battery, polaris 330 magnum voltage regulator, polaris 330 trailboss battery won't charge, polaris 425 magnum not charging, polaris atv battery not charging, polaris magnum 330 battery not charging, polaris magnum 330 charging, polaris magnum 330 not charging, polaris magnum 330 voltage regulator, polaris magnum not charging battery, polaris not charging, polaris not charging battery, polaris ranger batteries not charging, polaris ranger battery not charging, polaris ranger not charging
