**2000 250 xplorer counterbalance/tranny fluid help!!!*** - Polaris ATV Forum
Old 11-19-2011, 06:18 PM
plasticookie's Avatar
Member #20338
I have looked everywhere for counterbalance fill plug and transmission/gear oil dipstick. I found one plug low and right on the transmission section, but that's it and it's just a bolt...There is also a small flathead screw/bolt on the back of the engine just under the carb, but it has a hose running to the 2stroke oil reservoir connected to it. I'm about to pull my hair out!!! Also does the oil coming from the front reservoir serve any other purpose besides mixing with the gas??? Please help. Thanks 0.o
Old 11-19-2011, 06:46 PM
buddy_1's Avatar
Member #15674
The 250 engine does NOT have a counter balancer, so there is no oil to check. The trans dipstick is on the right side(sitting on quad) of the trans in frt of the drive sprocket by the brake fluid reservoir.
I know the "VOICES" aren't real but they have some great ideas.
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby, Comet clutch, Swamplites front & rear, 03 Predator Rear Hubs,
ITP Pro Baja Wheels (4x156 front & rear), DG Front Bumper, Fuj Rear Grab Bars and RZR Belt
Old 11-19-2011, 06:59 PM
Member #20338
i love you buddy! The bolt I found is right around were you are describing, but it wasn't a measurable dipstick and I put 11 ounces???? I also put a little(ounce or two) two-stroke oil in the crank for good measure. Good or bad idea?
Old 11-19-2011, 07:17 PM
buddy_1's Avatar
Member #15674
It may foul the plug when you start it. Have you just repaired engine or just doing maintenance?
Also forgot to mention that the oil from the front tank is the lubrication for the engine. So to answer
your previous question, Yes it does do more than just mix with the fuel.
1999 Sport 400 2x4
Old 11-19-2011, 07:23 PM
Member #20338
rebuild and maintenance....it mustve got hot for some reason and the rings pinched, causing it to lose compression. I honed the cylinder and bought everything to do a top rebuild. I'm also probably gonna disconnect the oil injector and just premix. But the top is currently disassembled.
Old 11-19-2011, 07:49 PM
buddy_1's Avatar
Member #15674
Hopefully you bought a Wiseco piston to replace the stock one. The stock pistons are ticking time bombs, it's not if they will grenade, but when. Also, have the cylinder bore diameter checked to make your going to have a good fit with your piston. Buddy
1999 Sport 400 2x4
Old 11-19-2011, 07:56 PM
Member #20338
ofcourse I did got any idea on exactly how much oil goes in the tranny?
Old 11-19-2011, 08:20 PM
buddy_1's Avatar
Member #15674
I've got a Haynes manual that states 27 ozs. But, it doesn't specify a year model. The manual covers "98 to 06" year models.
1999 Sport 400 2x4
2000 polaris 250 xplorer trouble shooting
2000 polaris explorer 250 service manuel
2000 polaris explorer 250 transmission
2000 polaris xplorer 250 4x4 transmission fluid
2000 polaris xplorer 250 transmission fluid
2000 polaris xplorer 250 transmission fluid capacity
2000 polaris xplorer 250 transmission oil
engine oil for a 2000 polaris exporer 250 4x4
how to check oil on xplorer 250
polaris exployer 250
polaris xplorer 250 crank case oil
starter - 2000 polaris atv 250cc fluid capacities
Sportsman 600 Tranny Fluid Question MOLLINS Polaris Sportsman 5 09-21-2011 03:34 AM
tranny fluid??? diesel133 Polaris Scrambler 4 06-18-2011 11:49 AM
tranny fluid rust1d Polaris Scrambler 6 09-14-2010 07:54 PM
09 850XP Tranny Fluid Low Polaris Bear ATV Repair and Maintenance 1 05-02-2010 10:55 AM
Tranny Fluid Level - 05 Scrambler 4x4 kevinvinv ATV Repair and Maintenance 0 03-04-2010 07:57 PM
