'96 Polaris xpress 400 maintenance - Polaris ATV Forum
Old 11-23-2011, 11:28 PM
Blackhawks1's Avatar
Member #20222
I just bought an Xpress 400.I'm going to be giving this thing some badly needed maintenance work before I start riding it.I've greased all the fittings,changed transmission oil,cleaned and lubed the chain, replaced the air filter,and changed transmission oil.My question is there anything else I need to do on this thing that is easily overlooked?Does the clutch need any kind of maintenance,such as lubrication?Thanks
Old 11-26-2011, 05:45 PM
poposcrammy's Avatar
Member #20152
uve done just about everything check ure 2 stroke oil make sure its clean check ure chain tensions and make sure its smoking some and that its using the oil and check ure radiator make sure its working and flowing good
1996 POLARIS SCRAMBLER 400
.025 ovebore wiseco
fmf grnarly head pipe stock silencer
25in swamp foxes
12 vision buckshot wheels
purple polaris sport seat to match shocks
v force carbon fiber reeds
reed spacer kit
uni airfilter
COMING SOON
Purple polaris sport hood
aftermarket silencer from hpd-inc.com
cluctch kit also from them
Old 11-26-2011, 09:56 PM
Member #20222
Thanks poposcrammy.I just ordered a dial-a-jet for it and a uni air filter.Do you know if this thing runs a mikuni vm carburetor?If it does I'm also going to order the ultimate flow optimizer from Thunder products.
Old 12-01-2011, 05:18 PM
Member #20152
ya mines got a mikuni on it so it should be the same cause everything on those older bikes are the same sides for the plastics and clutching.... also you should check your front hubs make sure there good and oiled spit them a bunch of times then take it and put it wer the screw is in the 3 o clock position and take out the lil screw if none comes out add repeat wait till a little comes out
.025 ovebore wiseco
25in swamp foxes
reed spacer kit
uni airfilter
COMING SOON
1996 polaris express 400 review
1996 polaris xpress 400
1996 polaris xpress 400 automatic transmission fluid
1996 xpress 400l
1997 polaris 300 express automatic trans fluid
1997 polaris xpress 400
1997 polaris xpress 400 review
how to drain the oil in a 96 polaris xpress 400
polaris 400 xpress specs
polaris xpress 400
polaris xpress 400 specs
Parting out a 1998 Polaris Xpress 400 4x4 ATV cyrjordan ATV Parts for Sale 2 02-27-2012 06:34 AM
1997 Polaris Xpress 300 Petcock rebuilt Nandy Polaris Sportsman 1 02-04-2012 01:50 PM
1999 Polaris xpress counrtygirl30 ATV New Members 1 03-25-2011 04:06 PM
1997 Polaris Xpress 300 Charging System Nandy Polaris Sportsman 1 09-05-2010 05:22 PM
Looking at buying a 98 Polaris Xpress tex599 ATV General Discussion 0 08-04-2010 07:37 AM
