2003 Magnum 330: Problems - Polaris ATV Forum
post #1 of 14 (permalink) Old 11-29-2011, 04:24 PM Thread Starter
Spuddie25's Avatar
Hey all. I cut a deal with guy today on 2003 Magnum. Currently the atv is stuck in 4x4, and it is believed to be a fuse that is out. To the same respect the winch is not working. Everything else seems to be operational with the exception of a few lights. Where do I need to look for this supposed fuse, and do you think it is realistic that this could be the problem?
Any advice would be appreciated, I haven't worked on an atv since I was about 16....I realized real quickly that they have changed.
Spuddie25 is offline
post #2 of 14 (permalink) Old 11-29-2011, 07:56 PM
Bruce! is offline
post #3 of 14 (permalink) Old 11-30-2011, 04:22 AM
Having a blown fuse CAN NOT make it be stuck in 4x4. It takes power to make it ENGAGE and a loss of power would just keep that from happening. You can try changing the oil in the front differential a few times and see if that helps but it probably has a worn or cracked roller cage or a bad armature plate.
polman500 is offline
post #4 of 14 (permalink) Old 11-30-2011, 09:20 AM Thread Starter
Spuddie25's Avatar
The fuse theory came from the idea that the electronic push button is not working. In other words, in theory, the fuse went out wen the ATV was in 4x4 and now can't get back to 2x4 because nothing happens when you push the button. Does this sound reasonable, and if so where would I look to find these supposed fuses? If not, I could be in for a bit expense then initially planned.
post #5 of 14 (permalink) Old 11-30-2011, 09:37 AM
MagnumGoose's Avatar
I think what polman is saying is the circut to engage 4x4 needs to be energized to engage, when it losses power, ei:blown fuse, it disengages. Not certain, but thats how I read it.
MagnumGoose is offline
post #6 of 14 (permalink) Old 11-30-2011, 12:11 PM
The Hilliard clutch in the front differential engages when an electromagnet pulls an armature plate toward it. Turn off the magnet and it disengages....unless something is worn, broken or stuck. Really nasty oil will cause them to stick sometimes. I suppose if there was a short in the switch it could theoretically cause it to stay on all the time but I've never heard of anything like that happening.
post #7 of 14 (permalink) Old 11-30-2011, 12:31 PM Thread Starter
Spuddie25's Avatar
Thanks for the insight. I am picking up the ATV tonight and will change the fluids first and see what happens. Hopefully I can sneak out of this with a reasonable price tag.
post #8 of 14 (permalink) Old 11-30-2011, 04:43 PM Thread Starter
Spuddie25's Avatar
Hey everyone. Picked up the Magnum 330 tonight. Fires and runs good, just need to give it a good cleaning so I can find the things I need to see. Can anyone list out the 123 for changing the differential fluids, and or direct me to a place that has the instructions? Illustrations would be helpful.
I am also looking for a good place to obtain a service manual if anyone has suggestions there.
2003 Polaris Magnum 330 4x4
post #9 of 14 (permalink) Old 12-11-2011, 06:17 PM Thread Starter
Spuddie25's Avatar
So I got all of the fluids changed....except the front gearbox which happens to be the location of the of the 4x4 engagement. According to the Polaris mechanic metal shavings collect and magnatize inside and can cause the 4x4 to stick. The previous owner never changed this gear oil and I now I think I know why. According to the manual it appears that I have the most difficult style to change. Has anyone ever changed this fluid before? Do I have to take off an outside case to get access to the fill location? Any help here would be appreciated.
Second subject. When I press the throttle there is a short delay in the rev as if it is not getting fuel right away. Any quick suggestions of things to check out to troubleshoot?
post #10 of 14 (permalink) Old 12-11-2011, 07:10 PM
SeanS's Avatar
make sure you use Demand Drive fluid only! do not put gear oil in that diff! i'm sure i've changed these before and don't remember having any problems. drain plug on bottom, fill plug on left side (when sitting on unit) at the front of the housing. fill to 3/4" below threads or 5.0 oz of fluid.
SeanS is offline
2003 Sportsman 700 problems focushunter Polaris Sportsman 5 10-18-2011 09:06 AM
2003 sportsman 400 AWD problems. Rodamatic80 ATV Repair and Maintenance 0 06-24-2011 04:33 PM
2003 Magnum Polaris Magnum ATV Performance Modifications 0 03-24-2011 02:37 PM
2003 Polaris Magnum Starting problems hunterbee68 ATV Repair and Maintenance 3 09-22-2010 12:41 PM
2003/ 330 magnum 4 x 4 DAISYBELL ATV Repair and Maintenance 1 06-28-2010 08:16 PM
