12-28-2009, 09:28 AM
Member #2460
99 sportsman 335 not charging battery
I have an electrical problem with my 1999 sportsman 335. when i put a voltage meter to the battery terminals when the atv is on..i get no voltage...can this be the stator or the voltage regulator...is there a way to test it...thanks..jose
12-28-2009, 12:50 PM
Member #2326
Most likely the Voltage Regulator. You can check the stator for proper ohms but not the VR. You'll need a manual for the correct ohms, It will tell you what wires to check across.
When you say you get no voltage, are you not reading the battery voltage?
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
12-28-2009, 01:37 PM
Member #2460
yeah i do read the voltage from the battery, its a new battery, i fully charge it and get around 12.7volts...as the atv runs, then it drops little by little...till it wont start no more...
12-28-2009, 05:17 PM
Member #2326
Ok that sounds like the Voltage Reg. I would check all my connection and wires just to be sure. VR is a common problem
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
01-09-2010, 10:39 AM
Member #2460
put in a new voltage regulator and still nothing....i get 37 volts from the 3 prong wire that comes from the stator...but nothing else..thanks
01-09-2010, 10:49 AM
Member #2326
On the VR, how many wires did it have?
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
01-09-2010, 10:56 AM
Member #2326
OK, check these wires for Ohm's with meter at wires coming from stator.
y to y/brown should be close to .17 ohm
y/red to y/brown should be close to .17 ohm
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
01-09-2010, 12:10 PM
Member #2460
ok, on the voltage regulator i have a 3 prong plug and a 2 prong plug and 3 seperate wires...a white, black and brown...thanks for helping me...
01-09-2010, 12:49 PM
Member #2460
ok, crossed the ohms test...on the 3 prong i got .39 and on the 2 prong i got .09..any ideas..thanks
01-09-2010, 01:55 PM
Member #2326
Is this what you replaced? Your description doesn't match this regulator. There are other boxes that look similar to this one but are not the regulator.
One of them is the rev box.
http://cgi.ebay.com/ebaymotors/POLAR...Q5fAccessories
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
1999 polaris sportsman 335 battery, 1999 polaris sportsman 335 charging system, 1999 polaris sportsman 335 manual, 1999 polaris sportsman 500 not charging, 1999 polaris sportsman charging output, 1999polaris sportsman not charging battery, 2000 335 polaris charger system, 98 polaris sportsman 335 alternator, 99 polaris sportsman 335 charging system, 99 polaris sportsman 335 charging system dian, battery polaris sportsman 335, charging system for a 1999 sportsman 500, charging system on a polaris 335 sportsman, polaris 335 not charging, polaris 425 charging problem, polaris 425 not charging, polaris magnum not charging battery, polaris not charging battery, polaris sportsman 335 battery, sportsman 335 not charging
