Sportsman brake problem, help needed... - Polaris ATV Forum
Old 12-03-2011, 07:50 AM
Olderatv's Avatar
Member #21031
New to forum and in search of some advice on this repair.
I have a 2001 Sportsman 500. Recently, the front wheels lock up after only a few minutes of riding. My 4wd doesn't work (Hilliards?) so I cannot place it in 4wd to "force" it to go.
If I leave the atv alone for 20-30 minutes, the wheels will start to rotate again but only for a little while before locking up again.
Any suggestions/experience with this?
Thanks in advance,
Johnnie
Old 12-03-2011, 10:31 AM
Old 12-03-2011, 12:44 PM
bosnjo's Avatar
Member #18373
The sympthom is tipical for a vehicle that has brake pads touching too much on the disk without breaks being aplied. This is usualy due to dirty/rusty break cylinder in one of wheels. What hapens is that on one wheel (usualy front one), the pads are locking a bit, and as you drive the bike, it develops very high temperature in the breaks oil due to a friction. As becoming too hot, oil expands too much and causes the cilinder to actuate like you've aplied the breaks. After some time, it cools down and "releases" the breaks. My sugestion, lift up your bike and rotate wheel by wheel by hand and see if they're all rotating freely. Then aply the brake, release it and rotate again. Repeat the process few times. You're looking for the wheel or wheels that will start feeling a bit dificult to rotate. If you find the wheel, there you go. You'll need to rebuild the cylinder on that wheel.
But first of all, before doing anything, make sure that new oil is in the brake system and system is without any air.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
2001 sportsman 500 brake problem
2001 sportsman brake issue
front brake problem on 2000 sportsman 500
polaris 500 brake problem
polaris atv brake problems
polaris brake problem
polaris sportsman 500 brake problems
polaris sportsman 500 brakes locked
polaris sportsman brake problems
polaris sportsman front brakes locking up
repair brakes/polaris sportsman
sportsman brakes lock up after riding a while
brake problem puckster5 ATV General Discussion 2 11-22-2011 04:22 AM
2000 sportsman 500 rear brake caliper problem gtl2571 ATV Repair and Maintenance 5 04-05-2011 03:15 PM
03 magnum 330 brake caliper needed kavetskilp Polaris Magnum 3 01-30-2011 11:10 PM
CV Boot Guards Are They Needed Or a Problem? athacker ATV Visual & Body Modifications 6 01-21-2011 05:14 AM
05 Sportsman 500 HO Rear Brake Problem jhartson ATV Brakes & Suspension 6 11-23-2010 02:47 PM
