from everything you have described it sounds like you need a new brush kit. please dont go buy a new starter right off the bat, you will be wasting a lot of money.
#3
3088169 CARBON BRUSH SET
Part was advanced to minimum order quantity 1 $67.54
Add Part# Description Quantity
1 3084981 Asm., Starting Motor [Incl. 2-5,7-11,13] 1 USAGE
2 3088163 Washer Set 1 USAGE
3 3088169 Brush Set, Carbon 1 USAGE
4 3088166 Nut, Flange 2 USAGE
5 3088165 O-Ring 3 USAGE
6 3082038 Bolt and Washer 2 USAGE
7 3085034 Asm., Bracket, Rear 1 USAGE
8 3088168 Asm., Armature 1 USAGE
9 3088160 Asm., Bracket, Front 1 USAGE
10 3088161 O-Ring 1 USAGE
11 3088164 Asm., Bolt Set [Incl. 5] 2 USAGE
12 3087030 Asm., Gear Shaft [Incl. 14-18] 1 USAGE
13 3088162 Ring, Rubber 2 USAGE
14 3083737 Washer, Gear Shaft 1 USAGE
15 3084412 Clip 1 USAGE
16 3084411 Spring, Weight 1 USAGE
17 3084410 Spring, Return 1 USAGE
18 3084409 Clip
