new winch, wiring help. - Polaris ATV Forum
Old 12-19-2011, 05:37 PM
atvman2010's Avatar
Member #8796
Talking new winch, wiring help.
so i assume not too many people love helping with these becuase its complicated but ill give it a try! my dad give me my new winch already. its a superwinch lt3,000 lb. i have a 2002 polaris sportsman 700 and have no electric smarts at all. before i dig in, are there any things anyone can help me out with? this thing has so many wires! haha thank you for any help you can give. great fourm here.
2002 polaris sportsman 700 twin 4x4-rear cargo box
-freshly rebuilt top end
2003 polaris trailboss 330 2x4-freshly rebuilt engine
1987 Yamaha Banshee 350 twin (sold)
1998 Yamaha badger 80 (sold)
1993 arctic cat 550 ext! (snowmobile)
Old 12-20-2011, 03:11 PM
atvman2010's Avatar
Member #8796
does anyone happen to know where to get a nice, cheap winch mount for this winch either? thank youuu.
Old 12-20-2011, 06:41 PM
Member #1958
Have you looked at the documentation that came with your winch?
Old 12-20-2011, 07:52 PM
50wing's Avatar
Member #20894
Winch
You can probably find a mount at KFI Products
ATV winches, mounts and accessories for KFI Products - KFI ATV Winch, Mounts and Accessories
I bought one from them last week, they shipped it within 48 hours, it fit nicely and they included mounting instructions.
Chuck
Old 12-24-2011, 06:33 AM
atvman2010's Avatar
Member #8796
thank you, i emailed that website and they are very helpful, the most helpful so far. i have looked at my wiring diagram, i was just looking to see if anyone had any tricks or anything to wiring.
Old 12-24-2011, 07:13 AM
50wing's Avatar
Member #20894
Wiring
When I mounted my Warn winch, the wiring that came with the winch was very long, much longer than I needed. Rather than rolling up the extra and zip tying it , I cut off the extra and soldered new ring connectors on the ends. I used shrink wrap.
It fit real nice and eliminated the rolled up "extra wire". If you do this, make sure you leave an extra inch or so on the ends in case you have to replace a connector at a future date.
Old 12-24-2011, 04:25 PM
Polaristech1's Avatar
Member #21078
The winch wiring is pretty straight forward just remember that all Polaris key on accessory circuits have a red wire with white tracer or an orange wire with white tracer and most have extra accessory connectors under headlight pod so you can plu the contractor switch in
Old 12-31-2011, 02:16 PM
atvman2010's Avatar
Member #8796
i got everything except there are 2 small red wires im suppose to connect to the key wires. its says to connect to brown/blue wires. the only wires i see are one set that has 2 wires one being purple and the other being brownish, and another set that is 3 red wires with white stripes.( and yes, these are the extra wires for mods.) which wires do you guys think i should use? thanks!
Old 12-31-2011, 10:37 PM
50wing's Avatar
Member #20894
winch
I mounted a Warn xt30 to my 850 last week. The red wires I connected under the headlight pod to orange wires that had white tracers.
One of my "hot wires" had a female connector on it so a "spade" connector could be pushed into it. The other wire I think had a rubber end on it.
Stick the "test light" probe into the end of each hot wire and the other end of the test light connects to a ground or the negative side of the battery. Turn the key on. If the test light glows the wire is "hot", turn the key off. The light should go off.
If you can find these you can use connectors to join the wires. I cut each wire and soldered them and used heat shrink wrap on each wire.
You should be good to go. GOOD LUCK !
You can test the wires using a "test light". Stick
2002 polaris sportsman winch install
atv winch wiring diagram
electric diagram for a winch on a polaris
polaris atv winch wiring
polaris ranger winch wiring
polaris ranger winch wiring diagram
polaris winch installation
polaris winch wiring
polaris winch wiring diagram
polaris winch wiring kit
warn xt30 wiring diagram
wiring diagram for polaris winch
ATV Warn winch wiring jim_pendley ATV General Discussion 1 12-17-2011 10:48 AM
winch wiring question BROWNING7WSM Polaris Sportsman 2 06-04-2011 03:39 PM
Wiring in a winch ddw304 ATV Repair and Maintenance 4 03-27-2011 04:07 AM
winch wiring dnhaarre ATV Repair and Maintenance 4 12-08-2010 06:04 AM
Wiring a non-Polaris winch mjscharlotte ATV General Discussion 4 11-05-2010 07:02 PM
