CV Joint reinstall - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 01-04-2012, 06:52 PM
circlip goes inside cv joint, you can buy a complete new axle from the cv man on e-bay cheaper than you can get the cv joint from polaris
  #12 (permalink)
Old 01-04-2012, 07:40 PM
OVoXO's Avatar
Member #20912
dont need a new cv joint...
how does it go inside the cv joint.. theres nowhere to put it....
  #13 (permalink)
Old 01-04-2012, 08:06 PM
OVoXO's Avatar
Member #20912
well, upon further investigation, the circlip stays on the end of the shaft (it was still there) so I just tested by pushing it into the ball bearing/cage and it locks in there.
  #14 (permalink)
Old 01-07-2012, 07:14 AM
OVoXO's Avatar
Member #20912
Job is done.. a manual and this link helped put the hub back together properly..
band on cv joint polaris sportsman
cv axle circli[
cv axle circlip
cv joint circlip repair
getting the circlips back into the differential on a polaris sportsman
how to get the bearings back into a polaris rear cv joint
how to install a sportsman front outer cv joint past the circlip
how to install axle into cv joint on polaris 500
how to install ball bearings inside cv joint
installing a cv joint that fell out of hub on atv
re installing rear cv axle on polaris atv
youtube cv joint
1999-335 u-joint to cv joint conversion 79tattop Polaris Sportsman 3 08-10-2011 06:06 PM
95 CV Joint turnwaldw Polaris Sportsman 1 03-24-2011 11:51 AM
U joint rifleman24 Polaris Sportsman 4 11-05-2010 06:31 AM
Rear tire ball joint CV joint? rich in co Polaris Sportsman 3 08-22-2010 02:55 PM
Help on a cv joint 02blk700 Polaris Sportsman 2 07-25-2010 09:12 AM
