01-07-2010, 09:00 AM
Member #2592
91 trail boss 350
do i need to have the starter and bendix gear in the machine for the charging system to work
01-07-2010, 09:18 PM
i dont think so, but how you starting it then? i wouldnt pull start it without the starter out because you run the risk of dirt getting sucked into the flywheel
01-07-2010, 11:07 PM
Member #2592
thanks i have pull started it the starter is in the whole i did think of the dirt and dust getting in its just not hooked up and the bendix gear was never there i just bought the machine and am working out all the bugs but the parts guy at JT's told me it had to be there for the charging system to work i didnt think so this would be the first time i ever saw hat but wanted to double check guess he just wanted to make a buck but im not paying 400 plus for something i can do with out
01-07-2010, 11:20 PM
yeah i just dont see why it has to be there for the charging system to work. all the bendix does is get throw out to get the flywheel going. once the engine is running the bendix isnt doing anything. the charging system gets it charge from the magnets spinning around the coils in the stator. im sure you could run it without the starter, just want to make sure the hole into the case is sealed up. could be "dirty" salesman....especially if he gets commissions on selling parts
01-07-2010, 11:22 PM
Member #2326
Agree with blueline, charging system is separate and has nothing to do with starter. You will be fine
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
1991 polaris 350 not charging, 1991 polaris trail boss 350 carburetor settings, 1991 polaris trail boss 350 carburetor settings,, 1991 polaris trail boss 350l charging, 1999 polaris 350, 1999 polaris trail boss charging system, 91 polaris trail boss 350, carb adjustment on 91 polaris 350, polaris 250 trail boss adjusting stator, polaris 350 charging system check, polaris trail boss 350 carburetor settings, polaris trail boss charging system, test polaris 350l bendix, trail boss 250 flywheel magnets dirty, trail boss 350 carb setting, trail boss 350l carburetor setting, trail+boss+carburetor system, trailboss 350 91 motor, utube 91 polaris, where do i find charging sytem on a polaris 1991 350 atv
