Old 01-12-2012, 10:03 AM
maverick11's Avatar
Member #3694
Bearings
Are the rear hub bearings the same as the front... just curious cause i need to replace mine and found a few cheap.
Old 01-12-2012, 12:40 PM
Member #1958
No not the same but not much more expensive either.
Old 01-12-2012, 03:10 PM
racer37l's Avatar
Member #5629
Rear: federal-mogul 510013
Front: federal-mogul 510014
Con
510013 bearing spec
federal mogul 510013
federal mogul 510013 specs
federal-mogul bearings 510014
Got a question about bearings 335polaris ATV General Discussion 2 07-21-2011 12:06 PM
How many crank bearings in a 500 02sportsman500 ATV Repair and Maintenance 1 07-12-2011 08:06 AM
front bearings cooper99 ATV Repair and Maintenance 4 05-29-2011 07:16 AM
Rear Bearings postman 444 Polaris Sportsman 1 11-21-2010 04:20 PM
Front Hub Bearings Currinjason@aol.com ATV Repair and Maintenance 1 03-25-2009 08:13 PM
