Old 01-13-2012, 05:18 AM
StevenWithaV's Avatar
Member #22027
02 Sportsman 500 H.O pull start decomp valve?
I have a 2002 Polaris Sportsman 500 H.O Remington Special Edition. Does this model have a decompression valve to help with the jerky pull start if needed? Can't seem to find one--where would it be? Thanks!
Old 01-13-2012, 06:36 AM
Old 01-13-2012, 08:03 AM
its a lever and spring that work off the button on the cam
Old 01-13-2012, 08:20 AM
Member #22027
Doesn't seem to have one. It will pull start ok you just get a lot of jerky tension on the string. If I get past the first part of the string I have about a good 6 inches of pull that tend to get it started. Just don't want to break the string! Could this model not have one?
Old 01-13-2012, 09:55 AM
tt425's Avatar
Member #3687
I had a 2001 Sportsman 400 and it didn't have a compression relief. Just give the rope a tug till it gets on exhaust stroke then pull it to start it. It should start at about 1/4 pull. What is wrong with the electric start? If it's the starter dbelectrical has a aftermarket starter and bendix(starter drive).
Old 01-13-2012, 07:49 PM
bmorton's Avatar
Member #22138
yea they do have a decompressor it is built into the camshaft. No there is not a button to hit for the decompressor, it is for the electric starter not you! haha. When using the recoil, pull it slowly untill it hits the hard spot, that is called tdcc, pull just past this then let your recoil rope back in so you can get a good pull on it and pull. If you try to just pull it and pull then yea you will break your rope and its an hour fix at the dealership and a job that most people dont know how to do by themselves cuz them recoil springs are a pain is the butt!
2001 polaris sportsman 500 ho decompression
2001 polaris sportsman decompression
2002 polaris sportsman 500 remington edition
2002 polaris sportsman 500 starter disassembly
2002 polaris sportsman 500 starter parts
500 polaris decompression valve
500 sportsman starts with pull rope but not with electric start
cant pull start polaris 500 ho sportsman
does the 2012 polaris sportsman 500 ho have a pull start?
photo polaris decompression spring
pilaris sportsman pull start
polaris 500 sportsman/ decompression switch
polaris decompressior valve
polaris sportsman 500 decompression valve
polaris sportsman 500 hard to pull start
polaris sportsman 500 pull start
pull start parts sportsman 500
pull starting polaris sportsman
sportsman 500 decompressor
Retrofit pull start 04 Sportsman 700 Tinpusher1 ATV Performance Modifications 29 05-23-2011 04:33 PM
Will and ATV ('05 Sportsman 500cc) start with the pull rope extended? NickS ATV Repair and Maintenance 6 05-18-2011 07:17 AM
2008 Sportsman 800 EFI Pull Start Location mattrob ATV Repair and Maintenance 2 01-01-2011 09:32 PM
oil in my pull start chris.wishart ATV Repair and Maintenance 1 08-17-2010 04:53 PM
91 sportsman 500 pull start doesnt return properly mcmarkrazz Polaris Sportsman 1 08-02-2010 07:52 AM
