01-13-2012, 11:32 AM
Member #22166
2003 sportsman 700 camshaft problems
I have a 03 700 that i bought new changed oil regularly at around 2300 miles the first lobe on the cam went flat, I had started running mobile 1 oil in it and figured that is why it went bad because they cut back on the zinc, so I put in a cam from hot cams and new lifters from polaris used break in oil for about 30 min than have run polaris oil since, well 300 miles later and cam has 3 lobes that are going flat. I am running it without a thermostate because I had a problem with it over heating before all this, so I don't know if this could be the problem or if there is an oil problem, I checked the oil pressure and it is good. any ideas would be helpful.
Thankyou
01-13-2012, 01:01 PM
havent heard of any 6-7-800 cam problems, I had a 03-700 put an 800ho cam and 40 mm carb on it, it ran good , used alot of gas, but never had any cam problems , had 5400 miles on it when I sold it, I use 5-30 Castrol Syntec in all my Polaris motors and tranny,s, have a 97-425 with prbably 9000 miles on it no cam problems,
01-13-2012, 02:16 PM
01-13-2012, 07:22 PM
Member #22138
have never heard of cam issues with the 6-7-or 8 polaris atvs. I have had so many of then come through the shop with different problems but never a cam! I would def put a thermostat in the thing! If by some reason that is what is causing the issue then they are way cheaper than a camshaft. The only polaris cam issues i know of are the older 500s after a couple thousand miles without regular oil changes they will wear out the exhaust came lobe and rocker.
01-17-2012, 11:34 AM
Member #22166
anybody else have an idea
01-18-2012, 04:15 AM
see if hot seat will warranty theyre cam , 300 miles isnt much
02-09-2012, 11:59 AM
Member #22166
Well talked to Hot Cam, and sent it in, and they are going to replace it and the lifters
02-22-2012, 12:04 PM
Member #22166
Can I reuse the metal Head gasket when I put this thing back together
02-22-2012, 02:44 PM
Member #23417
I've run Mobil 1 in every vehicle i own and never had one motor related problem in any of my cars...trucks...quads...bikes ever. I swear by the stuff and would recommend that oil to anyone. Hope you get to the bottom of your problem but i really don't think it was related to the Mobil 1 oil.
02-22-2012, 03:24 PM
no, need new head and base gasket.
2003 polaris sportsman 700 carb overheating, 2003 polaris sportsman 700 crankshaft, 2003 polaris sportsman 700 problems, 700 sportsman cam, 700 sportsman cam problems, camshaft 03 polaris sportsman 700, can i put a polaris rzr 800 cam shaft in a sportsman 700, hot cam crank for polaris 700, how to change a camshaft on a polaris rzr, how to repair 2003 polaris sportsman 700 atv crankshaft, oil level problems 2003 polaris sportsman 700, poalris sportsman 600 cam, polaris camshaft problems, polaris sportsman 700 cam worn, polaris sportsman 700 crankshaft, polaris sportsman 700 problems, polaris sportsman 700 twin cam worn out, polaris sportsman crankshaft, replace cam 700 sportsman, what oil to run in a 2003 polaris sportsman 700
