Old 01-14-2012, 02:03 PM
skizmo's Avatar
Member #13773
A Few Maintenance Questions!
I have decided to take all the plastics off my 2011 550 and give it a good cleaning..But I have ran into a few things where I could really use the advise of the vets on here..
1. I had to remove the gas cap from the 4"piece of rubber hose (attached with an O clamp) to get the front plastic piece off...but for the life of me I cannot get the piece that mounts to the plastic that has the thread on it (for the gas cap) off so that I can reinstall it on the rubber hose to close my gas tank up properly while I clean and service my bike...any tips would be great?
2. Upon removing all the plastics I have noticed the throttle cable where it comes down near the gas tank has rubbed on something and left about 1' X 1/8" exposed metal....Can I put electrical tape on this? or should I go get a new cable?
3. What if any, are there easy ways of cleaning all the small parts and getting in all the nooks and cranny's and any good products for restoring the luster to the metal parts?
4. Are there any places or parts I should be looking at that you guy's have noticed need special attention on these XP models?
5. Have you found a place to get the plastic rivets the hold the plastics together for an affordable price?
6. I have the bike jacked up the plastics off, the tires off and the battery removed to a tender..I have noticed that the brake pads slightly rub on the rotors...why and how do I fix this...Is it related to the battery being removed??? The bike was checked over in late September. and given its 50 hr service. The bike got a clean bill of health. But I have a feeling this issue could be related to premature break pad wear as I have replaced all 3 sets of brake pads in just under 1000 km...
Thanks for your help guys!
Get Some!
2011 Sportsman 550 XP Camo
ATV Logic Rear Storage Pack
Fin Grip Gun And Bow Holder
Custom 2-Up Seat
Pure Polaris Hand Guards
27' Swamp Lights
Polaris Front Lock&Ride Box
Ricochet A-Arm Guards (Black)
ATV Superstore 3 way Hitch
Garmin GPSmap 62
Old 01-14-2012, 02:31 PM
mr600twin's Avatar
Member #22300
some brake drag is normal check the caliper slides (make sure that the caliper moves back and forth)
Old 01-14-2012, 06:55 PM
skizmo's Avatar
Member #13773
Good to know..It is just a very slight drag, but I can hear a soft metal grinding noise.
I guess the premature brake pad wear really was my fault...LoL
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 01-14-2012, 07:12 PM
factionfx's Avatar
Member #20681
If the plastic clips on the plastic are the same as on the 2012 500 HO sportsman, you can get 20 or 30 on ebay shipped for about $5. search for "sportsman clip" Here is one such link ATV Fender Clips Polaris Sportsman Rangers Rzr Trail (C569) | eBay
2012 Sportsman 500, Red.
Old 01-14-2012, 07:14 PM
factionfx's Avatar
Member #20681
Actually, here is a better link... 6.25 for 25 of them. Searched for "polaris clips"
25 ATV FENDER CLIPS HONDA SUZUKI KAWASAKI POLARIS | eBay
Good luck!
Old 01-15-2012, 08:58 AM
skizmo's Avatar
Member #13773
thanks factionfx, I never was much of an e-bayer..but with that price, I am going to order them for sure!
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 01-15-2012, 12:58 PM
skizmo's Avatar
Member #13773
2 out of 6 answered!...That's not bad...only 4 more to go.
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 01-16-2012, 04:58 AM
factionfx's Avatar
Member #20681
No problem. I ordered some myself...now I don't have to worry about breaking them!
Old 01-16-2012, 12:30 PM
skizmo's Avatar
Member #13773
my issue was that I took of all the plastics off to clean and maintenance the bike, the clips that have mud stuck in them are a bitch to get out,so needles to say some are not useable anymore.
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 01-16-2012, 03:00 PM
xp74's Avatar
Member #4807
I mangled a few also when first taking the plastics off. when I removed the gas cap I used the cap of a spray paint can to cover the fill tube, it fit pretty good.
2010 550xp
how to remove oil filter from spotsman 2010 550 2up
how to remove throttle cable from 01 polaris 325
what is the a bar that attaches to the shock on 1994 polaris trail blazer 250
where does the rubber hose attached to the gas cap on a atv go to?
05 700 EFI Problem/Maintenance Questions RaggedEdges ATV Repair and Maintenance 4 08-28-2011 10:35 PM
2006 sportsman 800 maintenance questions usahoe18 ATV Repair and Maintenance 6 08-25-2011 05:11 PM
maintenance help meric ATV Repair and Maintenance 3 05-25-2011 05:07 AM
1994 Sportsman Maintenance and Repair Questions toshi38toshi38 Polaris Sportsman 5 03-25-2010 05:54 PM
93 Polaris 4X4 Maintenance Questions Predatorhunter ATV Repair and Maintenance 1 08-23-2009 10:22 AM
