Cold Start Help....
I went out to start my wheeler to let it run and give it some use so it doesn't just sit all winter and I can not get it to start via battery or by pull starting. It's a 2002 sportsman 400, the choke was all the way out when I tried this, I also tried to get it jumped after I charged the battery fully and it still would not start. I am going to check the plug tomorrow because I have a spare I can throw in if I need to. Unfortunately the machine sits outside, but it has been refueled and had stable put in the tank and run through the system before storage. The temp here today is about -5* - -10*F, any suggestions would be helpful. Also the battery is old, but I would have expected the machine to start when it was jumped even though this is the case, I have not invested in a battery maintainer yet as I just got the machine in the fall and was planning on replacing the battery in the spring as well as getting a maintainer for it. Typically she fires up first start with no choke, but it has never been this cold before starting, and it has been about a month and a half since it was run. Thanks again for any suggestions.
2002 Polaris Sportsman 400 4x4
