Old 01-16-2012, 08:38 AM
chuck2's Avatar
Member #20578
on demand 4x4
Hi There,\
Is there step by step instructions for repair of ON DEMAND HUBS any where in the forums ?
Thanks CHUCK
Old 01-16-2012, 12:12 PM
Kong's Avatar
Member #19350
What model and year. There are a bunch of links floating around for repair manuals. That would be the best place to start.
<a href=http://i283.photobucket.com/albums/kk293/luv2eather/Sigs/Kongsig3.png target=_blank>http://i283.photobucket.com/albums/k...s/Kongsig3.png</a>
Old 01-16-2012, 04:47 PM
Old 01-17-2012, 12:52 AM
chuck2's Avatar
Member #20578
on demand hub
Hi Kong,
Thanks for the reply, It's a 2002 Sportsman 500, 6x6. The right front hub will not stay locked in. It kicks in and out while the others are spinning. Thanks again for the reply, Chuck
i
Old 01-17-2012, 04:06 AM
change the fluid and see if that helps
Old 01-17-2012, 01:37 PM
chuck2's Avatar
Member #20578
On Demand Hub
Hi Ross, I took it apart and the axle bearing is gone, every thing is floating around What is the easist way to get it out and the new one in ?
Thanks for the reply, Chuck
Old 01-18-2012, 04:11 AM
if you have casle nut and washers off, hub should come off and bearings, nilliard clutch and armature plate should come out of hub, check that bearing races are ok, if not they need replaced too can get bearings from auto parts store, Timken #L44649 and L44643, they should have races too , get old ones out and take them with you
Old 01-18-2012, 01:23 PM
chuck2's Avatar
Member #20578
on demand hub
Hi Ross, I'll get at it and see how it goes.
Thanks for the reply Chuck
how to fix polaris 4x4 on demand
polaris on demand 4x4
polaris on demand 4x4 problems
repair polaris demand 4x4
timken l44643 polaris
timken l44649 & l44643
what is 4x4 on demand
On Demand 4WD Menchifus Polaris Sportsman 14 11-17-2011 02:17 PM
Demand Drive Fluid Alternative MANTEZ1 Around The Garage 2 02-27-2011 06:35 AM
polaris demand 4 drive rewire Firecat225 ATV Repair and Maintenance 2 01-23-2011 06:07 PM
demand drive fluid scott09 Polaris Sportsman 4 02-01-2010 08:24 AM
sportsman 500 on demand 4wd 07sportsman500 Polaris Sportsman 12 01-16-2010 03:20 PM
