Old 01-16-2012, 09:46 AM
spudman49's Avatar
Member #21186
Thumbs up Hilliard Clutch Polaris Explorer300
Fellas, asking a question. On a Polaris Explorer 300, are the right and left Hilliard clutch parts the same. In other words will the left fit on the right and vice versa. My right front Hilliard clutch, bearings, seals are completely destroyed. I bought the quad used. So I am in the process of buying some used parts off of ebay. They show both right and left Hillard clutch parts. Are there any difference. Thanks The Spudman
Old 01-16-2012, 03:41 PM
4getful2's Avatar
Member #1234
The outer castlelated nuts were different on the right and left, but clutches and garter springs were the same.
Old 01-17-2012, 11:00 AM
spudman49's Avatar
Member #21186
Thumbs up
Thanks for the reply. I will try and get the right side if possible and I am also chaing out the drive shaft and I have 2 used ones a right and left, so I am going to have to see hows the nuts go on. Thanks again The Spudman
atv hilliard clutch
hilliard clutch
hilliard clutch springs
hilliard clutch used
hilliard clutches california
hillyerd clutch
polaris hillard clutch
polaris hillard clutch spring
polaris hilliard clutch
polaris xplorer hilliard clutch problem
xplorer hilliard bearing
Hilliard Clutch Replacement Explorer300 spudman49 ATV Repair and Maintenance 1 01-11-2012 12:00 PM
trailboss hilliard clutch bowdog ATV Repair and Maintenance 2 11-30-2011 07:40 AM
87 trailboss hilliard clutch bowdog ATV Parts Wanted 1 11-30-2011 07:37 AM
I need a hilliard for 02 sportsman 02sportsman500 ATV Parts for Sale 2 06-09-2011 04:49 AM
02 Sportsman 500HO - AWD front hub not engaging hilliard clutch lock armature plate cookies ATV Repair and Maintenance 9 12-09-2010 06:48 AM
