Old 01-16-2012, 12:58 PM
Motsenbocker's Avatar
Member #22367
96 400 Sportsman ft hub leaking
Good afternoon, I am hoiping to get some technical advise for this machine that I have owned since new. I have been a mechanic for 30 years,,however not a Polaris Mechanic, that being said I am not a pro on these Polaris machines, I love this old thing and It looks like new and actually runs fantastic still. For several years now I have had a L ft hub that continues to leak. I have replaced the seal over about 10 years about 3 times. This time I am going to figure out the reason this continues to leak. First off, no matter how tight you tighten the front wheel bearings it is still loose (if you grab the top and bottom of the wheel when it is jacked up and wiggle) you know what I mean, just like if you were checking how loose the ft bearings would be on a car. Anyways the R ft has never had a leak or any problems. So, I ended up taking the wear sleeve off of the strut because it had a few light grooves.
Once I got that off I noticed that the ft strut assembly is not actually a one piece cast unit. The outer piece where the wear sleeve would press onto is actually not tight on the strut housing. I am assuming this is not normal ??
It also would make sense to me that this is the reason I could not get the ft bearings tight, (I am assuming that the outer race closest to that presed on part is allowing the race to be loose ?? Anyways do you have any advise?
Have you ever seen this piece that is loose? Also when I put the coil back in the new wear sleeve, there is a gap that should be in there right?
I hope someone can help
Mark
Old 01-16-2012, 04:48 PM
Old 01-16-2012, 05:03 PM
that piece is cast into strut and shouldnot be loose, do you have a manual?
Old 01-17-2012, 07:47 AM
Member #22367
Thank you, No I do not have a manual, I didnt think that it should be loose, I also think that was possibly the culprit for the leak. Has anyone ever seen this piece loose before?
Old 01-17-2012, 04:55 PM
Member #22367
Im thinking about taking that strut down to Polaris, If you ask me, Its a design flaw. noyhing i dod wrong to cause that casting to come loose. Any thougts? Has anyone seen this before?
atv front wheel hub loose
cause of leaking front polaris hub
how to fix a loose hub on atv
polaris atv leaking wheels
polaris hub leaking
polaris hub loose
polaris sportsman front hub seal leak
polaris sportsman hub leaking
sportaman polarise loose hub
sportsman hub seal
sportsman hubs leaking
tightening wheel bearing on 96 polaris sportsman
'98 Sportsman 500 leaking oil rowdyredneck Polaris Sportsman 0 10-23-2011 07:13 PM
2004 sportsman 700 leaking water rRandel ATV Repair and Maintenance 3 04-05-2011 03:50 PM
Leaking from front hub seal 99 sportsman 500 RMR ATV Repair and Maintenance 6 09-28-2010 01:56 PM
04 Sportsman 700 Leaking Coolant Sekora ATV Repair and Maintenance 4 06-04-2010 06:02 PM
2000 sportsman 500 leaking coolant kaboomb ATV Repair and Maintenance 2 09-23-2009 03:14 PM
