Old 01-16-2012, 03:00 PM
wjessup's Avatar
Member #21684
CANT GET OUT OF 4X4!! I need help!
I have a Polaris sportsman 03 600 and now can not get it out of 4wd, I have power at the switch so I think it is mechanical, can anyone tell me what might be the problem? Is it a solenoid? you should hear it engage when you flip the switch right? HELP!
Old 01-16-2012, 03:25 PM
4getful2's Avatar
Member #1234
If the switch is shutting off the juice,then the problem most likely lies in the front differential. TRy changing the fluid, see if it helps
Old 01-16-2012, 05:15 PM
change fluid and if that doesnt do it its probably broken roller cage in front diff, unhook wires at front diff and see if switch is turning it on and off, there is a plug in a couple inche from front diff
Old 01-18-2012, 06:36 PM
Mississippi_850xp's Avatar
Member #18015
If ur not using pure Polaris front diff fluid it will not come out of 4x4 or u could try going from forward to reverse that may help
Old 01-19-2012, 07:03 PM
HappyDaze's Avatar
Member #22412
I just went through the same problem, turned out for me it was the armature plate inside the diff, simple fix... once the diff was out. Kinda pricey in my opinion though $75 for the part from the local dealer. Also try checking the resistance in the diff, others correct me if I'm wrong but I think its suppose to be less then 26 Ohm
Tags
2003 sportsman, 600 twin, polaris
atv 4x4 switch broken
