Old 01-18-2012, 11:09 AM
uncbub23's Avatar
Member #10610
Winch Problems
I have a 2.5 warn winch on my 04 polaris sportsman 500. I have been having issues with the winch for a while now, if I leave it sit for a while the relay(i'm guessing thats what its considered) will click everytime I hit the in or out switch, usually all i have to do is tap the winch with a hammer and it'll start working but this time it didnt work. If it is the relay is there an easy fix, I got laidoff and cant afford to buy new. Any help would be greatly appreciated. Thanks in advance for any helpful advice.
Old 01-18-2012, 11:18 AM
Clinebo's Avatar
Member #9235
Do you have any corrosion at the cable connections? If tapping the winch body cures the problem I'd start there. Is the battery fully charged? I use a tender on mine if it sits for very long. Sorry to hear about the job loss.....My mill shut down 2 yrs ago and I'm still looking for work. Good Luck!
02' Sportsman 500 HO
Warn 2500
25" Grim Reapers
GoldFinger lefty throttle
Old 01-18-2012, 11:51 AM
uncbub23's Avatar
Member #10610
Thanks Clinebo, no there was no corrosion on connections there was alil dirt but i cleaned that up pretty good. I tapped on the winch for a while and nothing happened. Battery is fully charged. thats y im thinking it might b the relay because i know solenoids click when there bad. thanks for your help and good luck with your job search.
04 polaris sportsman warn winch problems
atv winch problems
did polaris fix the 2500 winch problems
fixing a polaris atv winch
polaris 2500 winch problems
polaris atv winch problems
polaris warn winch problem
polaris winch problems
warn atv winch problems
winch rebuild polaris atv
winch problems! amitoz ATV Repair and Maintenance 8 11-19-2011 04:19 PM
NEW..Polaris 2,500# winch problems ENCORE ATV Repair and Maintenance 7 07-08-2011 04:31 AM
Winch problems for 2010 550 EPS edgexc Polaris XP 9 02-17-2011 06:25 PM
winch problems rpayton 2010 3 12-24-2010 07:21 PM
Problems with winch mount RED850XP Polaris XP 4 12-06-2010 08:08 AM
