Old 01-18-2012, 05:42 PM
carralo1's Avatar
Member #22352
Lots of Play In Gear Shifter....
So just bought a 2000 xplorer 400 4x4. The guy said he put in a new gear shifter. Theres a lot of play in it though (Takes a few seconds to figure out where you are). Had other polaris autos and never had this much play. Is this adjustable? Could it be because maybe he put the wrong one in? Any advice would be GREATLY appreciated. Thanks
Old 01-18-2012, 06:26 PM
tt425's Avatar
Member #3687
It could be worn out. I think inside there is a plastic ball sphere(#3233646) that will wear out. You might could carefully take it apart,clean it and refill with new oil.
Old 01-19-2012, 02:50 PM
carralo1's Avatar
Member #22352
Took it off today there was no oil in there. Filled it with oil. Will check tomorrow and see if its any better. If not ill look into that ball. Should have read this before so I could have checked it then.
Old 01-25-2012, 07:53 AM
carralo1's Avatar
Member #22352
New oil makes it better. Goin into high and reverse feel pretty normal but low is tough to get into and feels weird. I notice there are 2 shifting
Linkages. The high and reverse use the same when I put in those gears and when trying to go in low, the left linkage tries to move but doesn't... Do I just have to
Adjust the linkage. Anyone have this problem before?
atv's cleaning the gear shifter
polaris outlaw shifter
polaris outlaw shifter problems
polaris sportsman part number 3233646
96 explorer gear box w/ shifter josh ATV Parts for Sale 2 03-19-2011 09:58 AM
gear shifter spring thepopeis1 ATV Repair and Maintenance 12 03-14-2011 04:06 PM
How to adjust gear shifter croghan23 Polaris Outlaw 8 03-10-2011 01:55 AM
05 sportsman shifter gear problem? daedaestoy ATV Repair and Maintenance 3 06-02-2010 06:54 PM
Shifter/Gear select Problems Hustler Polaris Sportsman 4 05-22-2010 12:16 PM
