Lots of play in transmission belt please help!
So just bought a 2000 xplorer 400 4x4. Stripped it down and checking everything along with new fluids,grease, paint etc. The guy said it has a new transmission belt he put in. So I took off the cover to check it and yes it looks new but there's a lot of play in it, (up and down when I press on top of the belt). My reason for removing the cover was 1. to see if it was a new belt like he said and 2. because when I test drove it, I had to give it a lot of gas to get it going, which seemed weird to me but I thought it might of had something to do with the carb because it needed to be cleaned(wouldn't idle and ran a little rough).
So What id like to know is how firm should that belt be when I press down? and seeing that its got a lot of play what will it do to harm anything in anyway? and how do I fix it? Thanks all
