Old 01-19-2012, 03:32 PM
carralo1's Avatar
Member #22352
Petcock Not shutting off fuel
2000 Xplorer 400 4x4. When I turn the petcock to off position it only slows flow of gas coming out of fuel line. Anyone have this happen to them before/how to fix? I had to clean out carb and now because petcock wont stop fuel its coming out of bottom of carb, havent investigated fully but its either the float or the o ring around bottom bowl nut or the bowl gasket. I'm going to get a new o ring and gasket anyway just to be sure. Any ideas on this would be greatly appreciated
Old 01-19-2012, 03:35 PM
carralo1's Avatar
Member #22352
Where do you guys buy your carb rebuild kits? Im thinking about 20 for a kit.. does that sound about right?
Old 01-19-2012, 03:45 PM
jordaman17's Avatar
Member #13240
1997-2002 Polaris Xplorer 400 Carburetor Rebuild Kit
Old 01-19-2012, 03:58 PM
carralo1's Avatar
Member #22352
Originally Posted by jordaman17 View Post
Thats perfect. Which of those parts is the needle seat? Ive worked on older toro snowblowers and the seat is a small white rubber piece. Don't see anything like that in pic. Never rebuilt one of these carbs. Thanks
Old 01-19-2012, 04:04 PM
jordaman17's Avatar
Member #13240
i can't really tell from that pic, but it says it's included
Old 01-19-2012, 05:53 PM
needle and seat are bad in your carb if gas is runnin out of bottom, most times when petcock wont shut off it needs replaced
Old 01-19-2012, 05:54 PM
tt425's Avatar
Member #3687
The part in the clear bag above the "o" ring is the needle seat. The fuel is coming out the carb because the needle seat is stuck open. The petcock needs to be replaced or use a universal in-line shut off. Prime line make a universal fuel shut off for 1/4" fuel line. Part # is 7-02324-1. You can buy it at most part stores.
atv fuel petcock
atv fuel shut off
atv gas shut off gasket
fuel coming out of petcock
fuel petcock for polaris 400l
gas not completly turning off atv
o-ring for fuel petcock
petcock not shuttig off fuel flow
petcock not shutting gas flow
petcock not shutting off fuel
polaris 400 explorer carburetor shut off
polaris atv fuel petcock
polaris fuel petcock
polaris fuel shut off
polaris pet cock
polaris petcock oring
polaris xplorer fuel shut off
polaris xplorer petcock
Carb issues. Float not shutting off fuel...it's cup runneth over! SturgisATV ATV Repair and Maintenance 4 01-14-2012 06:12 PM
Problem with fuel petcock..... mnmattie ATV Repair and Maintenance 0 08-15-2011 06:14 PM
2001 Polaris Trailblazer fuel petcock chevymuscle218 Polaris Trail Blazer 2 09-30-2010 01:22 AM
alternate fuel petcock / shutoff source or alternate to OEM laterongc ATV Repair and Maintenance 2 03-31-2010 07:48 PM
It keeps shutting down!!! Michaelcumberland ATV Repair and Maintenance 1 02-23-2009 09:22 AM
