Old 01-20-2012, 05:58 AM
jac42779's Avatar
Member #17976
Clicking Noise In Reverse?
I have a 2005 Sportsman 700 that when in reverse it makes a clicking noise. I'm thinking that it's probably a driveshaft but was wandering why it would only do it in reverse. I have jacked the bike up and tried finding which one it might be but it will not make the noise when it's off the ground.
Also the two front driveshafts have a lot of play where they go into the front gearbox, is this normal for Polaris? I have had the front driveshafts out and the front gearbox all apart recently for work and everything looked good.
Old 01-20-2012, 07:46 AM
lost cause's Avatar
Member #9763
There is some play with the axles in the the differentials. No big deal unless it is totally just sloppy all over the place. As far as the axle popping goes, sometimes when the joint is not completely broken they will pop in reverse or when you turn, but not when going straight. Just has to do with how the load is applied to them. Have someone else drive it in reverse and you look at the axles. If it is popping you should be able to see which joint is moving slightly.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-20-2012, 08:51 AM
bosnjo's Avatar
Member #18373
I had this in my previous ride, CanAm. Even if I pushed it backwards in the straight line, I could hear the clicking with engine off. I looked arround very well and found on the rear driveshaft one of U-joints that had some free play. Changed it and noise was gone.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
Old 01-20-2012, 03:48 PM
jac42779's Avatar
Member #17976
My rear joints do have a little play. Maybe I will start there and see if that helps. Thanks Guys!
Old 01-21-2012, 12:27 AM
bosnjo's Avatar
Member #18373
Let me put it this way:
when I found a little play in one of joints, I said to my friends I didn't want to bother with it, I can live with that clicking, I didn't want to do anything. But they all jumped (much more experienced owners of many brands) and said I was crazy, it's not something to play with, it'll only get worse and if it brakes (and it will), the damage would be exremely expensive. They scared me and I changed U-joint straight away.
So, even if those U-joints, with some free play you talk about, aren't source of your clicking noise, they need replacement.
- Wind deflectors
- Front Brush Guard
- Car tires
- Road legal
Old 01-21-2012, 04:26 AM
its probably one of the cv jointson the axles
atv axle clicking
atv clicking noise from axle
atv making clicking noise in reverse
clicking noise from rear of sportsman 700
clicking noise on polaris
clicking noise reverse 500 sportsman
clicking noise when backing up 06 polaris sportsman 700
gorilla axle popping
polaris 800 universal joint? popping noise
polaris atv clicking noise
polaris atv clicking sound
polaris makes a clicking noise when backing up
polaris outlaw how to rebuild rear axle
polaris outlaw reverse ticking
polaris sportsman clicking noise in reverse
rear end making noise when backing up on my atv
rear ticking noise polaris outlaw
sometimes its a clicking noise when im in reverse
why is rear gorilla axle clicking
'09 sportsman 500 clicking noise cdwladr ATV Repair and Maintenance 3 04-30-2012 04:17 PM
Right side clicking noise? Kalani938 ATV General Discussion 12 01-20-2012 10:13 AM
Clicking noise from rear end. gramslam05 ATV Repair and Maintenance 5 12-01-2010 02:09 AM
Clicking noise by starter bighaas ATV Repair and Maintenance 1 09-08-2010 05:57 AM
09 850xp clicking noise? Breakineven ATV Repair and Maintenance 1 08-02-2010 07:18 AM
