Old 01-20-2012, 09:12 AM
Tikka338's Avatar
Member #21578
01 sportsman 400 wont start when 6 pin connector is plugged into headlight pod
Hi was wondering if anyone can help me with a problem
My 2001 polaris sportsman 400 turns over when I turn the key but wont start...I unplug the 6 pin connector in my headlight pod and it starts right away,but without the 6 pin plugged in I have no awd ,speedo wont work and I can over exceed the usual 7mph in reverse without it wanting to stall meaning no over ride is needed......Im starting to think maybe a short in a wire or something can someone help me with this please as well as is there a part number for for a new 6 pin connector and wires? thanks alot
2001 Sportsman 400
Symtec Heated grips & Thumb Warmer
Moose HandGaurds
2000lb Warn Winch
Gun Boot IV - Realtree
Custom Bush Bumper
Old 01-20-2012, 12:22 PM
Polaristech1's Avatar
Member #21078
The black wire in the 6 pin connector is the ign. kill circuit. The easiest way to see if you have a wiring problem in this circuit is to locate the cdi box and disconnect the black wire. This effectively eliminates the entire ignition kill circuit. plug in 6 pin connector and try to start atv. If it starts you have a break in the black wire ign. kill circuit somewhere. You will have to re-connect black wire to shut atv down. let me know if this doesnt work and i can help you dignose further.
Old 01-20-2012, 03:52 PM
Tikka338's Avatar
Member #21578
k will try it next time, my atv is out at the cabin and im a couple hours away right now is it possible u message me a few more diagnoses as I do not have internet there and would be easier to just print these message and bring them with me when i go to work on it thanks
2001 Sportsman 400
Moose HandGaurds
2000lb Warn Winch
Custom Bush Bumper
Old 04-04-2012, 09:47 PM
Tikka338's Avatar
Member #21578
well reading my repair book i got on the atv and from what uve said seems like it is the kill switch circuit is there a way i can bypass this? as i want my speedo and awd to work again
2001 Sportsman 400
Moose HandGaurds
2000lb Warn Winch
Custom Bush Bumper
01 sportsman 400 wiring diagram
01 sportsman wont run with spedometer plugged in
2001 polaris 400 sportsman. wont start
2001 polaris sportsman 400 cdi
2001 polaris sportsman 400 wiring
2001 sportsman 400 wiring schematic
hard starting sportsman 400
how to re-wire a 2001 sportsman 400
how to start a sportsman 400
how to start atv winch plug
polaris 400 wont turn over
polaris sportsman 400 short wire
polaris sportsman 400 wont start
polaris sportsman handlebar switch plug
sportsman 400 hard start
2002 sportsman 400 wont start new stator. have spark wont fire roadjoker22 ATV Repair and Maintenance 9 01-18-2012 04:36 PM
99-01 Sportsman Left Handlebar Switch- On/Off/Start/Headlight noslofivoh ATV Parts for Sale 3 08-25-2011 11:25 AM
sportsman 500 EFI wont start schalid ATV Repair and Maintenance 5 08-18-2011 01:49 PM
Sportsman 500 wont start Rebelcbowhunter ATV Repair and Maintenance 2 07-19-2011 10:25 PM
Sportsman 500 wont start. incadave Polaris Sportsman 2 11-02-2010 03:43 PM
