Old 01-20-2012, 03:08 PM
mascasa's Avatar
Member #22480
Replace Choke Lever Xpress 300 96
New to the board. Great resource.
I am a newbie to ATVs, but purchased a decent 96 Xpress 300 for a couple hundred bucks. Figured a good way to learn without a lot of investment.
The choke lever is broken and I purchased the new kit below.
Choke Lever Replacment Kit 0119 from Polaris ATV Repair Kits
However, when I removed the old choke, it has a black box with the choke cable coming out of it. Did I buy the wrong thing? I don't see how I would remove the cable from the box or open it.
On a potentially related note, my buddy cleaned my carb for me. It now starts after about 10 seconds, but won't idle. I am thinking the choke will help with this, but any recommendations would be appreciated!
-Mascasa
Old 01-20-2012, 03:18 PM
Old 01-20-2012, 06:22 PM
mascasa's Avatar
Member #22480
Figured it out myself. By the back of the box there is a VERY small seam. It almost looks like there isn't one there. Delicately prying and eventually using a 3mm flat head and a hammer I was able to separate the box. Took about 10 minutes. Then about another 10 minutes of putting in the new lever and presto it is good as new!
how to change a choke cable to a lever
how to disconnect choke cable on 2010 300 polaris
how to remove choke cable from polaris atv
how to replace choke lever on polaris
how to replace polaris choke lever
polaris 300 choke
polaris 300 where is choke
polaris choke lever disassembly
polaris choke lever replacement
polaris x-press 300 choke replacement
replacing a chocke lever on a atv
replacing choke for atv
whats the choke lever for on a atv
2000 polaris choke lever replacement MAVERICKWILD ATV Repair and Maintenance 3 12-17-2011 08:54 PM
Dual Brake Lever Mod Q's djr8505 Polaris Scrambler 5 01-04-2011 05:44 AM
Replacing choke lever and cable? Sulteric ATV Repair and Maintenance 2 12-13-2010 09:53 AM
Broken choke (lever or plunge?? not sure) on 01 TB redrider Polaris Trail Blazer 10 09-13-2010 05:52 AM
Xplorer Choke lever kajun ATV Repair and Maintenance 1 04-26-2010 06:28 PM
