Old 01-20-2012, 04:30 PM
switchbackfst's Avatar
Member #22482
95 sport 400 issues
Hi guys! New to the site and having a stressed out day lol. I have a 95 sport 400. It has spark, 110 compression, and getting fuel. The problem is there is not even a fart out of it. Has anyone ever had this issue before or steer me in the right direction? I am thinking timing but hard to sett idle at 3k to check when it wont even run! Pleeeeeeease help, Thank u
Old 01-20-2012, 04:47 PM
carralo1's Avatar
Member #22352
Have you tried sprayin some starting fluid through the carb and see if it'll fire?
Old 01-20-2012, 04:57 PM
Member #22482
I tried squirting some fuel in the spark plug hole but had no luck.
Old 01-20-2012, 05:01 PM
carralo1's Avatar
Member #22352
Well if you did that the plug might be wet now.. Someone correct me if I'm wrong. Id pull the plug, check it then spray some starting fluid through carb. Just a thought. You got spark, compression and fuel.. Should fire. I don't thinking timing would be that far off to not let it atleast fire
Old 01-20-2012, 05:03 PM
Member #22482
kinda what i thought about the timing. I did pull plug and heat up with mini torch and retried but nothing. I will try some starting fuel
Old 01-20-2012, 05:07 PM
carralo1's Avatar
Member #22352
Ya give that a shot. Usually works for me. Post back and let me know how it turns
Out
Old 01-20-2012, 05:13 PM
Member #22482
Sounds good. It will be tomorrow. I've given up for the night lol.
Old 01-20-2012, 05:15 PM
carralo1's Avatar
Member #22352
Yeah I know all about that hah
Old 01-21-2012, 04:36 AM
try a new plug,
Old 01-21-2012, 02:42 PM
Member #22482
well sprayed a little starter fluid thru carb, runs but pings and backfires which brings me back to timing issue. carb is spotless, new plug solid strong spark, and wont rev up. does any one know the proper stator and flywheel combo? This quad belongs to a customer and really has me stumped!
95 polaris 400 timing
95 polaris sport 400 compreshion
95 sport 400 carb polaris
polaris 400 black wire rev limiter
polaris timing issue
sport 400 issues switchbackfst Polaris Scrambler 0 01-20-2012 04:00 PM
Sport 400 no go.. Mark13 ATV Repair and Maintenance 12 01-07-2012 08:53 AM
99 sport 400 jlewan88 ATV Repair and Maintenance 1 04-07-2011 06:53 AM
Need help with issues on 97 400l sport Prembird ATV Repair and Maintenance 15 08-28-2010 10:41 AM
99 400 sport cyrus1762 ATV Performance Modifications 2 07-12-2010 10:54 AM
