Old 01-20-2012, 05:19 PM
onion224's Avatar
Member #19458
2000 Sportsman 500, light problem
Hello,
I have a 2000 Sportsman 500 and the low beam lights are not working. Also before this happened, my speedo had quit working. The speedo has been out for a while but the Low Beams just quit working. The High Beam still works. Is there a fuse or breaker to check? Or is there something else to check?
Old 01-20-2012, 06:01 PM
Old 01-20-2012, 07:08 PM
NaturalElement's Avatar
Member #20009
Battery. Is it cold? I wonder what the sequence of failure for Polaris is when you have a bad battery? My winch went, then the throttle, but not the lights. Check the battery, the cold will kill it.
Ryan
Natural Element
www.earthh2ofire.com
'09 Sportsman XP 550
Old 01-21-2012, 04:33 AM
burned outbulb or broken wire in headlight pod
Old 01-21-2012, 06:48 AM
onion224's Avatar
Member #19458
Battery is new. On the 2000 Sportsman 500 the Low beams consist of two lights, they both went out at the same time. Are there fuses that can be checked? Or some kind of relay?
Old 01-21-2012, 07:42 AM
Kevcules's Avatar
Member #14887
I think your headlight has to be replaced if one of your bulbs is burnt.I'm guessing if one of the bulbs work , then the fuse is not the problem.
If your speedo is not working , your hall effect sensor is probably shot. It should be on the right side front caliper bracket.(around $50)
Kevin
2000 sportsman 500 lights
2000 sportsman low beam and fan wont work
all polaris atv lights just quit working
hi beam light for 97 sportsman
high beam not working on polaris 500 sportsman
highbeam light problem polaris 500 sportsman
how do i get all light to work on the 2012 sportsman 500 on high beam
light not working on 99 polaris sportsman 500
lights stopped working on sportsman
low battery sportsman 500
polaris 500 sportsman low battery
polaris sportsman 500 lighting issues
polaris sportsman 500 lights do not work
polaris sportsman 500 no speedo lights
polaris sportsman high beam not working
97 sportsman 500 light problem? OHsneaky1 ATV General Discussion 5 01-26-2012 08:36 AM
2000 Sportsman 500 Cooling Problem mjt ATV New Members 5 01-20-2012 12:15 PM
2000 Sportsman 500 over heating problem Ilikemud ATV General Discussion 13 11-06-2011 02:21 PM
2000 scrambler light problem rodneyplaisted Polaris Scrambler 1 01-16-2010 10:13 AM
2000 Sportsman 500 ho starting problem dodgeboy528 ATV Repair and Maintenance 5 12-19-2009 04:29 PM
