Old 01-21-2012, 06:44 AM
04sportsman's Avatar
Member #9578
2000 Polaris Sportsman 500 Motor Lock Up???
The last 2 times I have tried to start it, it will turn for a split second, then lock up. I try pulling the pull cord and nothing. Eventually ther eletric start will turn it, then after that, it turns over fine and starts right up. Motor runs good and no abnormal noises coming from it. I seem to think it maybe the compression release, cause it locks, will turn slow, then seems once the piston is on the decompression stoke, its turns freely. Anyone got any ideas? Is this a common problem?
Old 01-21-2012, 07:45 AM
Kevcules's Avatar
Member #14887
They do have a lot of compression and that's why it's hard to turn over. If the electric start doesn't turn it over ,then your battery isn't charged well enough or you need a new one. Maybe your starter is going bad also.I have a 2001 and haven't had to use my pull start much but when I do, if you catch it at a certain spot , it does pull hard. Once by that spot , it's easier... Fairly common I think...
Kevin
Old 01-24-2012, 03:27 PM
Member #9578
I had my battery on charge for a few days. Went to start it today after sitting for a few days, and again, turned for a split second, then locked up. Pull cord would not budge. After turning the key a few times it finally broke loose and turned over and started fine. I got to think its a compression release issue? Can you work on the compression release without tearing the motor apart?
Old 01-25-2012, 01:20 AM
4getful2's Avatar
Member #1234
Try using jumper cables with a known good battery. if that doesn't help ,then yes you can work on it without taking the motor apart. Just remove the valve cover and you're there. hopefully there is room to work on it.
There's not much to the decompressoe, a spring and a lil ball, so it may be time for a cam, try adjusting the valves first --set all at .006" at top dead center. inspect cam lobes too.
Old 01-25-2012, 01:45 PM
Member #9578
So I tried something different today. I tried pull starting it first rather than using the electric start. It pulled 3 times fine with no lock up. I then hit the electric start and it fired up fine. Maybe it is just something in the starter drive, but we will see if I'm that lucky.
Old 01-25-2012, 04:01 PM
maybe bad brushes in starter, try hiitin the starter with a bar or hammer next time it does it, if it starts, starter going bad
Old 01-28-2012, 03:56 PM
sportsman 500 H.O's Avatar
Member #14325
I too have the same problem with my 2009 500, i had the starter rebuilt, new battery, checked all the grounds and ignition wires and have just replaced the spring in the compression lock, went to start it and it still locks up. The engine runs fine and even with this problem the engine always starts but it really bothers me and Polaris isn't doing anything to help me.
2009 Sportsman 500 H.O
Black SS rims
26" itp mudlites
Old 01-28-2012, 04:35 PM
I have one with 11to one compression and it does it occasionally, let go of starter button and try again and it fires up, have learned to live with it, if it comes up on compression just right, starter wont turn it
Old 01-29-2012, 02:45 PM
john luttrell's Avatar
Member #14602
Hello, it looks like you have covered most of what could cause the slow cranking, but have you checked the valve clearance? If the valve clearance is too loose, the check ball that the compression release cam holds in place, to momentarily release the compression will not contact the rocker arm for the exhaust valve; it has to make contact in order to bump the exhaust valve off it's seat momentarily in order to release the compression. If the valve adjustment is correct and it still does not release the compression, there is a chance that the check ball has fallen out, I have heard of this happening, but have never seen it myself. The check ball is on the back side of the center cam lobe and you should be able to see it with the valve cover off; you may need a small mirror to get a visual, but you should be able to see if it's missing.
The bad thing is, that you can not, to my knowledge buy a new check ball and keeper, which means you would need to buy a new cam shaft to get it. That would be a question to ask a good parts man though. As far as adding an extra wrap on the release spring, I'd advise against it, as the spring needs to be light enough to allow the release check ball to completely disengage the rocker arm when centrifugal force over comes the spring at around 300 rpm, or you could possibly burn a valve. The valve clearance on both the intake and exhaust valves is .006" and here is the page from the manual on how to adjust them, in case you don't have the manual for it. Hope this helps, don't hesitate to get back with me, I'm sure we can get it figured out. I also attached a good pic of how the spring should be installed, it will not operate correctly if installed wrong.
Old 01-30-2012, 01:30 PM
Member #14325
I did a valve adjustment in the spring and the valves were at .006. The other day when i was replacing the spring in the compression lock, i had the valve cover off and did check to see if the ball in the cam was still there and could see that it was. I spun the clutch and did see that the ball was opening and closing the exhaust valve properly. I just keep thinking that the spring i ordered doesn't have enough tension to operate the decompression lever. The engine does not do it all the time, it starts fine some times and starts slow other times.
Black SS rims
26" itp mudlites
04 polaris sportsman 700 motor locked
2000 polaris sportsman 500 for sale
2000 polaris sportsman 500 starter issues
2000 polaris sportsman 500 starter motor
500 sportsman motor
97 polaris xplorer 500 compression release
atv starter locked
cannot keep starters on polaris sportsman 500
how do you install a sportsman 500 decompressor
how to fix a atv motor if it is locked up
polaris 500 locked up
polaris locked up engine
polaris predator 500 decompression lever
polaris sportsman 500 keeps burning up starters,
polaris sportsman 500 timing
polaris sportsman 500 wiring
polaris starter locking up motor
pull start rope locked up on 250 polaris
what causes an atv engine lok up
wjat to do if atv motor lock
does the 2011 polaris sportsman 500ho have a diff lock polariskid13 Polaris Sportsman 1 06-08-2011 11:09 PM
Polaris 335 Sportsman motor $ 250 shawn.m ATV Parts for Sale 1 05-15-2011 06:29 PM
2000 Sportsman 500 motor swap jechampion ATV Repair and Maintenance 6 02-21-2011 07:59 AM
2003 polaris sportsman 700 motor questions outdoorsman2011 ATV Repair and Maintenance 1 02-03-2011 02:01 PM
2000 polaris sportsman 500 03 trail boss ATV Purchasing and Price 5 01-14-2011 04:53 AM
