01-21-2012, 07:30 AM
Member #21958
2000 Xplorer 250 4x4 starting issues
I have a 2000 Polaris Xplorer 250 4x4 and it has electric start. When its cold out the electric start takes a really long time to get it going. you will be sitting there for five or ten minutes cranking it over to get it going. What could cause this problem?
01-21-2012, 10:04 AM
Member #22352
Make sure choke is on. Give it a little gas when cranking. These machines have trouble
Starting in cold.
01-21-2012, 11:00 AM
Member #21958
Starting in cold.
Yea choke is on. It seems to start easier with a battery charger hooked up to the battery.. May more CCA than 220? or new battery? PO said he out a new battery in it. kinda looks new.
And it doesnt help that i broke the pull string for the the pull start
01-21-2012, 11:03 AM
Member #22352
If the engine is cranking slower
When no battery charger is hooked up then I'd say replace battery. But if it's turning over with the same power then that shouldn't affect it..
01-21-2012, 11:06 AM
Member #21958
Yea It seems to crack over slower without charger.. Maybe Ill replace the battery here in a little bit.. Thanks for the Help. Really appreciate it.
Member #22352
check battery voltage With multimeter between the terminals. Then push and hold start button while
Checking voltage( may need two ppl). Voltage shouldn't drop below 9 or 10 volts I believe.. Someone correct me if I'm wrong. If it does, time for
New battery
01-21-2012, 11:08 AM
Member #21958
New battery
Alright, Ill give her a check in a little bit. Thanks again.
Member #22352
Yeah telltale sine of bad battery. Walmart sells some for 25 bucks. Not the best battery's but they're a whole lot cheaper haha. Goodluck!
2000 polaris 250 4x4, 2000 polaris 250 4x4 motor w starter, 2000 polaris xplorer 250 no start issue, 2000 polaris xplorer 250 wiring connectors, 2000 polaris xplorer 250 wont start, atv takes a while to start, battery 2000 polaris xplorer, does the polaris 250 have electric start?, electric start kit xplorer, how to remove starter from 2000 polaris 250 4x4, polaris 250 4x4 battery location, polaris xplorer 250 4x4 wont start, polaris xplorer 250 will not start, polaris xplorer will not start, polaris xplorer wont start when cold, removing starter 250 polaris xplorer
