did you check the wires running down the strut?sounds like one is broken, look around the clamp thats on bolt that holds shock in strut, other wise its new coil time, you say it kicks in once in awhile, thats why I think its in the wiring, ,try puttin it on jack stands and runnin it, wiggle wires and gear shift er to see if you can make it come on, might also be shifter switch
