Old 01-21-2012, 03:36 PM
bburke's Avatar
Member #21640
2000 trail boss strut!
i am trying to install my new strut that i just ordered but im not sure how to get it back on because the spring. any idea?
Old 01-21-2012, 03:56 PM
res2cue's Avatar
Member #15153
Here is an easy way to compress the spring to get it on using ratchet straps
Old 01-21-2012, 04:00 PM
res2cue's Avatar
Member #15153
here is how I did mine using the above idea when I changed out my ball joints
Ball joint write up
Old 01-21-2012, 04:03 PM
bburke's Avatar
Member #21640
thank you very much!
Old 01-21-2012, 04:12 PM
res2cue's Avatar
Member #15153
Hey BB, Youre welocme!
and you dont live in Manville RI do you?
Old 01-21-2012, 04:21 PM
bburke's Avatar
Member #21640
no i live in NJ
Old 01-21-2012, 04:26 PM
bburke's Avatar
Member #21640
okay so im still a little confused, i went out to my quad to check it out but right now i have the new strut off and ready to go on but the spring isnt really connected to anything so i cant use the straps. uhh i dont know
Old 01-21-2012, 04:31 PM
res2cue's Avatar
Member #15153
all you are trying to do is compress the spring itself, enough to get the top mounted then attach the ball joint then release the straps CAREFULLY!
Old 01-21-2012, 04:34 PM
bburke's Avatar
Member #21640
yes i will be very carefull while doing it! and okay ill probably do it tomorrow. a little to cold out now
Old 01-21-2012, 06:20 PM
bburke's Avatar
Member #21640
worked great! use the straps and it was easy! got my quad good! thanks so much
2000 trail boss captin30 ATV Repair and Maintenance 7 06-28-2011 07:52 AM
2000 trail boss 325 TrailbossMan ATV Performance Modifications 4 02-17-2011 05:11 PM
2000 Trail Boss ??? cwlongshot ATV Repair and Maintenance 7 10-27-2010 07:04 PM
2000 Trail Boss 325 MUDMUDMUD ATV General Discussion 2 07-09-2010 08:24 AM
2000 trail boss 325.... help? lea89n ATV Repair and Maintenance 0 08-16-2009 06:14 AM
