01-21-2012, 03:47 PM
Member #22523
Ground cable starter to battery 2001 sportsman 500 ho
Is there an easy way to replace this? Can find it in my repair manual. Help
01-21-2012, 05:33 PM
01-21-2012, 06:43 PM
Member #3687
Welcome to the forum. I had a 2001 Sportsman 400 which is similiar to a 500. It didn't have a ground cable from starter to battery. Not sure what you are talking about. Can you post a pic?
01-22-2012, 04:34 AM
yeah, only positive cable to starter, grounds itself when mounted
01-22-2012, 05:29 AM
Member #22523
The neg battery cable sorry
01-22-2012, 03:22 PM
Member #3687
The negitive(-) cable and ground cable are the same. The positive(+) cable or hot(red) cable should be the only cable hooking to the starter. If there is anyway you can post a pic it would help alot.
01 polaris 500 starter, 2001 polaris sportsman 500 starter, 2001 polaris sportsman 500 starter removal, 2001 polaris sportsman 500 starter replacement, 2001 sportsman 500 starter removal, cable starter polaris 500 ho, how to install battery on a polaris sportsman 500, polaris 500 atv ground locations, polaris 500 ho starter diagram, polaris 500 starter removal, polaris atv ground wire locations, polaris battery cable location, polaris battery wire, polaris sportsman 500 battery location, polaris sportsman 500 grounding the starter, service manaul polaris 2001 sportsman 500 ho, sportsman ground cable, where do you ground battery cable on a atv, where does the ground cable connect on a polaris 500 sportsman, where to ground to chassis from battery polaris 2000 sportsman 500
