Old 01-21-2012, 08:02 PM
StarGazed0123's Avatar
Member #22531
Pull Clutch on a 1994 Polaris 400 Xplorer
I need to pull the clutch on a 94 xplorer so I can get at the starter to get it off. Can anyone give me instructions or direct me to where I can get reliable instructions on how to pull the clutch properly? I have already removed the recoil housing and the skid plate is welded to it, so I can't remove it, hence why I need to remove the clutch to get to the starter. Any help is greatly appreciated! Thanks!
Old 01-21-2012, 11:02 PM
starpuss's Avatar
Member #16228
it's not hard to pull the clutch. it will not fly apart on your. Stick in your puller stick on your impact gun. Give it shit and she is off.
i am going to be making a youtube video on this mid next week or so.
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 01-22-2012, 04:29 AM
as stated, need the right tool and an impact wrench
Old 01-23-2012, 08:23 PM
Member #22531
we got the starter out... did end up getting the skid plate off after grinding off where the morons welded it on... it went pretty quick after that....
Tags
400, clutch, starter, xplorer
1994 polaris 400 clutch
1994 polaris 400 pull
1994 polaris 400l atv recoil rebuild kit
clutch puller polaris xplorer
how to fix 1997 polaris xplorer 400 clutch
how to pull a clutch of a. polaris atv
how to pull a clutch off a polaris sportsman 400 '97
how to pull polaris xplorer clutch
how to remove a master clutch from a polaris 400
how to remove clutch on polaris 400
how to starter replacement polaris 400 sportsman#gsc.tab
polaris explorer clutch tool
polaris xplorer clutch puller
polaris xplorer starter removal
polaris xplorer starter removal video
polaris xplorer starter replacement video
remove clutch polaris sportsman 400
remove pull start 97 polaris sportsman
removing clutch on on polaris
where is the starter located on a 1994 polaris sportsman 400
1994 polaris 400 4x4 94polaris400l ATV Wheels & Tires 1 09-04-2011 06:48 PM
1994 Polaris Xplorer 400 Need Help abar ATV Repair and Maintenance 1 06-23-2011 05:56 PM
1994 polaris 250 trailblazer clutch cover jlwofter Polaris Trail Blazer 3 02-01-2011 06:02 PM
anyone please DO I NEED TO PULL CLUTCH TO REPLACE STARTER ? 01 sportsman mcmarkrazz Polaris Sportsman 2 08-23-2010 02:32 PM
Newbie here: ? about clutch on 01 xplorer ortz_02 ATV Repair and Maintenance 2 08-10-2009 09:20 AM
