Old 01-22-2012, 10:56 AM
jacobt4's Avatar
Member #11685
Fuel gauge sticking
Ok, here is my latest problem. After asking this forum for help with the carb on my 2005 sportsman 500 this past summer (and by the way,the help was dead on on solving our carb issue) and while doing other maitenance work, my son and I took the fuel tank off of the machine. We turned it upside down to drain all the gas out of it and set it aside for about a week while we did the work on the carb.
Since we have put everything back together, the fuel gauge always reads full. Does not matter how much gas is in the tank. I have tried taking the body parts off to make sure all electrical connections are connected and I can find no wires that are not connected or loose.
Did we do something to the tank by turning it upside down? Or is there maybe a wire that I am just missing? Any help would be greatly appreciated. I do not like letting my 15 year old son take the atv on rides and him not knowing the gas level.
Old 01-22-2012, 04:09 PM
bgirard420's Avatar
Member #11494
Just guessing, but it sounds like you got the float stuck somehow. Especially if it was working fine and then after reassembly it's giving you a problem. I would see if you can't free it up somehow.
To test the sender you take the tank off and hook an ohm meter up to the plug that comes off the tank on the middle and far right prongs. It should read 5 ohms when empty and 90 ohms when full (+/- 5%). If it's not between this range or erratic than you could have a faulty sender.
2010 Sportsman 500 H.O.
Old 01-23-2012, 11:42 AM
jacobt4's Avatar
Member #11685
Thanks for the info. I will try playing around with the float tonight and if that does not work, my son and I will take the tank off this weekend. If I need to replace the sending unit, where would be the best place to buy one? I don't have anyone local that I trust in getting a decent price. I know that if I have to replace the whole tank, that it will be expensive but I don't like the people who run the local Polaris dealer in Altoona, Pa
Old 01-23-2012, 04:56 PM
bgirard420's Avatar
Member #11494
I read this post a while back, maybe it will help you? Smart dude repaired his "unserviceable" sender with parts from a local store.
fuel tank removal help
Hopefully it's just a stuck float though and you won't need to do any replacing. If you have to go the route of changing the tank I found this at hit the gas:
Hit-The-Gas New and Used OEM Parts for Polaris, Yamaha, Suzuki, Kawasaki, ATV, Jet Ski, Motorcycle, Ranger, and Dirt Bike
It kills me that you can't just buy thee sender but thankfully your tank assembly is a little cheaper than the 2010s.
fuel gage always showing full
fuel gauge allweys full
fuel gauge for polaris atv
how do i fix a stuck gas tank float on an atv
kawasaki atv fuel gage
Fuel Gauge Disappeared. Polaris1_00000 ATV New Members 2 12-13-2011 05:23 AM
Fuel gauge tricky27x ATV General Discussion 6 07-06-2011 06:46 AM
fuel gauge pal95mon ATV General Discussion 2 12-27-2009 07:15 AM
Fuel gauge not being accurate (Rep) sjcarp ATV General Discussion 6 09-30-2009 07:20 AM
Fuel gauge sjcarp ATV General Discussion 0 09-03-2009 03:03 PM
