Old 01-22-2012, 11:28 AM
06Polaris11's Avatar
Member #22550
06 sportsman 700 efi wont go
I have 700 with 29.5 outlaws,todayi went out and it rode fine for awhile then i heard a popping noise from the front diff and about 5min later it shut off so i tried to start it and it runs rough and the engine will bind when reved up and will not move under power .if reved high enough the belt will start to burn.i also noticed theres some fluid leaking out by the shaft.the atv will move if pushed but not under power. Any help would be appreciated
Old 01-22-2012, 03:40 PM
Member #22550
Anyone
Old 01-22-2012, 05:49 PM
Old 01-23-2012, 04:11 AM
sounds like you broke the belt, take clutch cover off and see
Old 01-23-2012, 05:19 AM
Member #22550
Ok il try that. Thanks
Old 01-23-2012, 06:28 AM
Member #22550
Ok belt was destroyed ,now my question is should the front shaft have alot of play in it ?
Old 01-23-2012, 04:00 PM
are you talking about shaft tat clutch is on , front drive shaft , which?
Old 01-23-2012, 04:06 PM
Member #22550
The front drive shaft has a bit of play in it. Could this have to do with the clunking noise i heard beforemy belt broke? Also when in high gear it took alot of throttleto get moving,would that be belt slip?
06 sportsman 700
atv wont go belt
atv wont move in drive
polaris sportsman 700 wont go out of 4
polaris sportsman 700 wont move
sportsman 700 efi wont run
sportsman wont move
2002 sportsman 400 wont start new stator. have spark wont fire roadjoker22 ATV Repair and Maintenance 9 01-18-2012 04:36 PM
awd wont disengage on my 02 sportsman oldiron4ever ATV Repair and Maintenance 1 11-26-2011 07:02 PM
99 335 sportsman wont go into awd dchilders1962 ATV New Members 3 08-09-2011 05:08 PM
05 sportsman 90 wont rev up gatorchaser ATV Repair and Maintenance 3 05-22-2011 12:17 PM
98 sportsman wont run frenchslandscape ATV Repair and Maintenance 1 11-21-2009 11:36 AM
