Old 01-23-2012, 04:44 AM
superman73's Avatar
Member #12279
97 sportsman 500 wont fire, ive replaced stator and flywheel, help
my 97 500 sportsman quit and i found a destroyed flywheel and stator and got a used flywheel and stator from a 2003? scrambler 500. the scrambler flywheel is the type with the enclosed magnets and the stator tested good when i ohmed it with a tester. it still wont make a spark at the spark plug. could the cdi be bad? how do i check it? what steps do i need to take? i rebuild volkswagen motors, chevy, ford and all, but i cannot figure out this ignition system on this four wheeler. help please!
Old 01-23-2012, 05:16 AM
bezerk1's Avatar
Member #20465
Check the pulser coil to flywheel gap.
Old 01-23-2012, 01:31 PM
5hundredpolaris's Avatar
Member #22269
there is a good chance it could be your cdi. could also be your coil. check all wires and grounds. also check etc switch. that was the problem with mine
Old 01-25-2012, 03:16 AM
superman73's Avatar
Member #12279
the pulser coil will not move if you loosen it. i tried to move it. the cdi box may be bad, the guy i got it from said the scrambler had been sitting for some time. i changed the coil already. its not getting any fire from the white/blue wire.
Old 01-25-2012, 03:03 PM
Member #22269
i would really pull toward the etc first. that was my problem. i baught new coil cdi, and sparkplug. when i never had to spend a dime. take the throttle box cover off and looks at it. its the cover above the thumb throttle. there are two metal leads. if they touch, it wont fire. make sure they are not touching and see if it fires. i just put something between my leads to stop it.
Old 01-26-2012, 06:12 AM
superman73's Avatar
Member #12279
i left the black wire from the cdi unplugged, i figured it was the kill switch wire. still no spark.
Old 02-24-2012, 10:46 AM
superman73's Avatar
Member #12279
i just got a new cdi box and it still doesnt fire. i dont what to do now. if i spin it over, it put out like 35-36 volts from the stator thru the black/red, red wires. does anyone have a color chart or picture of the wire plug in for the cdi for the 2003 sportsman/scrambler? my white/blue coil wire broke off from the plug and i reattached it to the metal prong inside the plug, just want to make sure i put it back in the right place. i guessed at it. also, does the sportsman have a red/white and red wire attached on the side of the plug?
01 sportsman stator gap
500 sportsman stator
97 polaris sportsman 500 no start
four wheeler wont fire after stator replacement
how many volts does a stator put out on a sportsman 500
how to install a stator on a polaris four wheeler
how to take off polaris sportsman 500 flywheel
how to take off polaris sportsman flywheel.
how to take the flywheel off a polaris sportsman 500
how to test a polaris stator
polaris sportsman 500 stator
polaris sportsman 500 stator test
polaris spotsman stator
polaris wont fire
replace stator polaris 97 500 atv
scrambler 500 wont fire
stator replacement on four wheeler
what voltage does. 98 sportsman 500 stator put out
why wont my 97 polaris sportsman 500 fire
wiring a polaris stator
2002 sportsman 400 wont start new stator. have spark wont fire roadjoker22 ATV Repair and Maintenance 9 01-18-2012 04:36 PM
need flywheel, stator, and cdi box for 97 sportsman 500 superman73 ATV Parts Wanted 0 01-12-2012 04:08 AM
Just replaced flywheel and now it stalls...? herman0203 Polaris Predator 9 05-13-2011 12:47 AM
98 Sportsman 500 flywheel and stator easymoney ATV Repair and Maintenance 3 06-21-2010 11:04 AM
Stator & Flywheel Sheruft Around The Garage 4 02-03-2010 06:44 AM
