Old 01-23-2012, 07:25 AM
schmidm90's Avatar
Member #22264
Fuel in Oil
Hey Guys,
I cleaned the carb on my 98 Magnum 425 about 3 weeks ago. It ran great for two days then it became hard to start. I checked the oil level and the first two days it was good. Then when it became hard to start the oil level started to go up. The oil does not really smell like fuel, but that is the only explanation I can come up with. I turn the fuel off every night. Could it be that something in the carb is still dirty and the fuel from the carb is getting into the oil? That would explain why it is hard to start(no fuel) and the oil level rising?
I am going to pull it apart tonight and re-clean everything.
Thanks for any feedback!
Old 01-23-2012, 08:07 AM
factionfx's Avatar
Member #20681
The needle and seat could be leaking on it. So even though the fuel is turned off, there is still fuel in the carb and line that could be leaking past the needle/seat and getting into the engine. We had this on a yamaha breeze a while back. Fixed the leaking needle and changed the oil a couple times and it was good to go.
2012 Sportsman 500, Red.
Old 01-23-2012, 08:19 AM
schmidm90's Avatar
Member #22264
I will take it all apart tonight and try to clean it. How can I determine which needle/seat is leaking in the carb? ALso any good tricks on how to remove the choke and throttle cables?
Old 01-23-2012, 08:38 AM
factionfx's Avatar
Member #20681
I'm not sure on the tricks fore removing the choke/throttle cables on your bike.. If they are like my bikes, throttle should just be able to unscrew the the slide (and assembly) and place it in a towel, and leave it there. The choke should just be a (plastic) nut, and the whole choke assembly should come out. I'd put it in a towell and leave it there as well.
My float needle had a rubber tip on it. If it is sticking open (like yours) or closed (like mine was; couldn't get it started), it is my understanding that there is no 'cleaning' to it; it just needs to be replaced.
When I say needle & seat, I am referring to the float needle and the seat that goes around it. I don't know of a way to check that they are leaking, I can only tell you that I had mine replaced on the 325 when he pulled it apart to fix the not starting issue. (it wasn't getting fuel, and the fuel pump was working). Parts were about $40 and he was not ripping me off; they are that expensive from polaris.
Mine has been working great for about 1.5 yrs now.
Old 01-23-2012, 04:47 PM
schmidm90's Avatar
Member #22264
Hey Guys! I took the carb out tonight and am having a few problems. I got the main jet out along with the needle. I have a manual I was following on how to take it all apart and clean it. The one thing I am looking for is the air mix screw that has the o-ring that is causing fuel to leak into my oil. I am attaching a picture of what I am looking at so maybe someone can help me. According to the manual it says there should be a screw in the place where the brass plug with the hole in the center is. It says to turn the screw all the way in and record the number of turns for re-install. If anyone can help that would be great! Thanks!
1998 Magnum 425 4x4
Old 01-23-2012, 04:57 PM
factionfx's Avatar
Member #20681
Check out the attached image. It is off the Sportsman 500 but the carbs look the same. I think P, L, M, and N are what you are asking for.
Old 01-23-2012, 05:06 PM
schmidm90's Avatar
Member #22264
Thanks for the picture. Is there a diagram of the bottom of the carb? I am trying to figure out where the fuel could have been leaking into the oil from. The fuel was leaking from the bottom of the carb, I dont think it was coming from the choke. The bowl was empty when I opened it today and I ran it a few days ago, so I think there should have been fuel in it. Thanks again for all your help.
1998 Magnum 425 4x4
Old 01-23-2012, 05:16 PM
factionfx's Avatar
Member #20681
You're welcome. Attached. 'C' is the needle valve assemble I was talking about in earlier post. That is where my problem was, except mine was stuck closed; sounds like yours is stuck open...
Old 01-24-2012, 04:07 AM
in your firsttpicture, the brass plug is farthest to left, have to drill it out with 1/8 "bit, dont drill too deep, insert sheet metal screw into plug and remve brass cap, throw cap away, air screw is under brass cap, set at 2,5 turns out, looks like you got the needle and seat and float apart,need to remove both jets and clean with carb cleaner ad compressed air
Old 02-04-2012, 06:08 AM
schmidm90's Avatar
Member #22264
Thanks Russ!! I ordered a rebuild kit for a Magnum 500 and most of the parts work, but you need to double check each individual piece before putting it in.
It runs great now!!
Thanks again for all your help!
1998 Magnum 425 4x4
Tags
fuel, hard start, magnum, oil
05 trail boss getting fuel in oil
2000 polaris trail boss 325 leaking oil through air breather
atv fuel in oil
fuel in oil polaris
gas in oil 98 polaris sportsman
gas in oil on new polaris
gas in oil on polaris 500
gas in oil on polaris atv
gas leaking into oil in atv
gas leaking into oil on a atv
how to changing oil pump on 98 trailblazer
polaris 250 trailblazer how to remove needle jet
polaris atv gas in oil
polaris magnum 425 choke diagram
polaris magnum 425 leaking oil
polaris sportsman carburated smell fuel in oil
polaris sportsman oil smells like gas
polaris trailblazer carb image
remove polaris air fuel brass block
why my polaris 325 leaking gas into the motor oil
Oil and fuel in air box kelly ATV Repair and Maintenance 2 12-29-2011 03:03 AM
2001 trailboss wont start, fuel issue, fuel pump? Judd ATV Repair and Maintenance 5 02-20-2011 08:05 AM
no fuel Mark Foucher ATV New Members 4 01-23-2011 10:38 AM
800 x-tra fuel Ryano Polaris Sportsman 6 03-28-2010 09:28 AM
06 500 x2 fuel inj. no fuel toadtwelve ATV Repair and Maintenance 1 01-28-2010 04:24 PM
