Old 01-23-2012, 07:46 AM
backshift's Avatar
Member #22589
4x4 problem
2004 polaris sportsman stuck in four wheel drive.
Old 01-23-2012, 07:50 AM
Old 01-23-2012, 03:53 PM
what model sportsman?
Old 01-23-2012, 06:20 PM
backshift's Avatar
Member #22589
2004 polaris sportsman 600
Old 01-24-2012, 03:59 AM
roller cage broken in front diff
Old 01-24-2012, 06:45 AM
backshift's Avatar
Member #22589
is it easy to fix? and why do they breaK? i hear guy's just leav them becaus they just break again.
Old 01-24-2012, 01:57 PM
they usually break cause people are spinning rear wheels and push awd button, knock on wood I have never broke one, have fixed a couple of other peoples, if you back off throttle then push buttopn it wont break
Old 01-24-2012, 06:38 PM
backshift's Avatar
Member #22589
thanks for info. i hear johndeer gator parts are the same and a lot cheper. have you istalled these. if so how do they work just as good?
2004 polaris sportsman 600 stuck in 4wd
4x4 problem
polaris 4x4 problem
polaris 600 4x4r issues
polaris 600 sportsman 4x4 problem
Carb problem or fuel problem? cumberlandguy ATV Repair and Maintenance 0 09-04-2011 04:36 AM
