Old 01-23-2012, 08:18 AM
dtret's Avatar
Member #12482
Question awd will not engage in forward gears
my 700 sportsman efi [2005] will not engage awd in forward gears but does in rev. had a broken hub but replaced it and put new oil in any ideas
Old 01-23-2012, 03:47 PM
700s dont have hubs, probably broke roller cage in front diff
Old 01-24-2012, 06:13 AM
dtret's Avatar
Member #12482
yes they do i broke the splins the hub
Old 01-24-2012, 09:27 AM
lost cause's Avatar
Member #9763
did you put the correct polaris oil in. If you don't use the polaris stuff you will have issues. Other issues are broken sprague cage or warped armature plate.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
all wheel drive will not engage polaris
polaris start in gear with awd switch off it will not engage
would a broken rear axle cause four wheel drive not to engage on a polaris atv
Cam gears slipped? JoeW Polaris Predator 7 Yesterday 07:54 PM
Gears slipping?! Polaris600 ATV Repair and Maintenance 17 01-24-2012 01:45 PM
Front Hubs/Gears xprider Polaris XP 0 03-06-2011 11:22 AM
Lower gears? eswiger ATV Performance Modifications 3 10-04-2010 05:29 AM
How do i time the gears? dfhind77 ATV Repair and Maintenance 0 04-07-2009 09:00 AM
