Old 01-23-2012, 11:05 AM
ch312's Avatar
Member #22596
04 engine in an 02?
hey all, i was just wondering if a 2004 700's engine will work in an 02 700? if so, can you just drop it in or will some modding be required to make it work?
thanks
Old 01-23-2012, 01:47 PM
Old 01-23-2012, 02:04 PM
Corey850XP's Avatar
Member #15824
It will bolt right in, reuse your 02 stator, flywheel and your good to go. I have done one, takes about 4 hours and you will be up and running.
Old 01-25-2012, 03:06 PM
ch312's Avatar
Member #22596
thanks guys.
so, what parts will i be able to use on the 04 from the 02? i havent got a hold of the 04 to see it's exact condition, but for the most part the 02 motor is still fine.
will the 04's carb work perfectly in the 02 machine or will cables need to be modified?
Old 01-25-2012, 03:51 PM
carb is the same
Old 01-25-2012, 04:02 PM
Corey850XP's Avatar
Member #15824
Carb and cables with work fine. Whats wrong with your 700?
When to Fog a Engine cadpat ATV Repair and Maintenance 5 01-10-2012 12:51 PM
Fog the engine? skizmo ATV Repair and Maintenance 9 12-06-2011 04:32 PM
what engine do i have? lbmfpeterson Polaris Scrambler 3 11-19-2010 10:06 AM
400 HO - who's engine?? WilliamBos Polaris Sportsman 0 06-03-2010 02:46 PM
engine unstoppable crawlers ATV Repair and Maintenance 7 09-13-2009 08:11 AM
