Old 01-23-2012, 01:35 PM
5hundredpolaris's Avatar
Member #22269
2004 sportsman loud whining sound??
when moving at above 20mph, i get a super loud whining sound.. sounds lie it is coming from the front.. please help. IT SOUNDS LIKE A #$@%!%$ JET ENGINE!
Old 01-24-2012, 12:31 PM
Member #22269
aaaaannyyyy helpp....
Old 01-24-2012, 01:32 PM
take belt cover off and see if belts bad
Old 01-24-2012, 02:39 PM
Member #22269
belt is fine. clutch looks good. works as it should. no water in system.i noticed that the foot brake does absolutely nothing??? do you know why? it doesnt slow me down or anything..
Old 01-24-2012, 05:56 PM
factionfx's Avatar
Member #20681
Most likely the foot brake just needs to be bled. It is on a seperate reservoir and there is a seperate bleeder valve for it (versus the main hand brake systems)
2012 Sportsman 500, Red.
Old 01-24-2012, 06:11 PM
Member #22269
where is the bleeder vlave? are these brakes really that important? my hand brake works fine
Old 01-24-2012, 06:14 PM
factionfx's Avatar
Member #20681
The bleeder is on the caliper.
Old 01-24-2012, 11:54 PM
bosnjo's Avatar
Member #18373
I had the same kind of sound on my previous ride, CanAm. After belt change it was still there. Sold it like that as I just couldn't find the source.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
2004 250 polaris trailblazer what does override do
2012 polaris sportsman 850 whining noise
polaris belt whining noise
polaris sportsman loud whining noise
polaris sportsman whine
polaris sportsman whining
polaris sportsman whining noise
Wats a loud nice sound exhaust for 04 sportsman Polarisguy57 ATV Performance Modifications 7 06-24-2011 12:11 PM
97 magnum 4x4 loud sound and 4x4 questions barber878 Polaris Magnum 3 01-25-2011 10:57 AM
polaris sportsman 500 ho 2004 grinding sound marlboroman ATV Repair and Maintenance 2 11-08-2010 08:40 PM
06 800 EFI whining sound from rear grub Polaris Sportsman 0 10-02-2010 05:15 PM
Loud Clanking sound before shuttoff Egroothand Polaris Trail Blazer 0 09-05-2009 02:50 PM
