Old 01-25-2012, 10:44 AM
maverick11's Avatar
Member #3694
Rear Hub
I am working on replacing my rear wheel bearings but I cannot figure out how to remove the hub. I have the bolt on the top a-arm removed and the 2 bolts on the side of the lower a-arm removed but I don't know how to pull the hub off. It is still attached to the lower a-arm.
Old 01-25-2012, 11:03 AM
jac42779's Avatar
Member #17976
The bushings that go thru the a-arms recess into the hub about 1/2 inch. You have to use some pliers and slide the bushings back a little and that will free up the hub for removal. May have to spray some lube on the bushings if they have not been off in a long time.
Old 01-25-2012, 11:45 AM
Member #1958
Yeah, what jac said above...I usually just take the bolt and stick it about half way in the bushing and wiggle it and pull out slightly while holding up on the carrier to take the pressure off. They usually work out pretty easily.
how to get rear wheel hub off of polaris
WTB: Rear 2011 850xp Limited Edition Black Rear Wheel llsht14 ATV Parts for Sale 2 09-05-2011 07:48 PM
rear wheels for front and rear??? krzykrakr Polaris Sportsman 5 04-19-2011 01:56 AM
Rear Prop Shaft Turns -- Rear Wheels do not fz1oakville ATV General Discussion 2 02-25-2011 12:32 PM
will a scrambler 500 rear shock fit on a 500 predator rear? hunter51190@yahoo.com ATV Brakes & Suspension 1 10-18-2010 04:18 PM
